Results 1 to 6 of 6
Thread: 2d part on tormach 1100 with spurt cam
    Jun 2011
    U.s.a.
    I just got a tormach 1100. I am trying to cut out a completely 2d part. I cannot seem to find a tutorial that covers what needs to be done in sprutcam to set the part up. Does anyone have any information or a good tutorial?
    Again this is a completely flat 2d part.
    Sep 2005
    Did you check out the videos Eric at Tormach has done? He has covered several items in enough detail to get you going.
    David in the UK also has some videos for a nominal charge.
    The manual with SC has also greatly improved from a few years back when there basically wasn't one. If you have a specific question you could ask that and someone here usually can answer.
    Robert
    Jul 2004
    What kind of file are you starting with? If DXF, import it and use 2D contouring opp.
    David
    Registered R.DesJardin's Avatar
    Aug 2008
    Profile
    Finishing-2D countouring. Pick you profile curve. Make sure you get you offsets correct. Really simple, I use this feature a lot.
    RAD. Yes those are my initials.
    Idea, design, build, use. It never ends.
    Jun 2011
    U.s.a.
    Ok thanks for your help. Figured out 2d contouring. Now I have a few more questions. I am making a small flange test part just a circle with a bolt hole pattern. I simulated it and sprit cam has it mounted in thy additional axis attachment. How do I set it where it's
    Just mounted in a vice on the table. Second I can't figure out how to reference the tool location. How do I tell it where to start from. Third I can't figure out how to adjust the drilling depth. It just drills a little bit into the plastic.
    Thanks for any help,
    Zach
    Jun 2011
    U.s.a.
    It keeps wanting to use this rotary table. I disabled the extra axises and it keeps the part chucked up in the rotary table . What do I have to do to disable all the extra axises and just clamp the thing to the table.
    1. Newbie- GibbsCAM to Tormach PCNC 1100
      By dolecki in forum Post Processor Files
      Last Post: 05-26-2010, 05:02 PM
    2. Tormach 1100 software
      By remout in forum Tormach Personal CNC Mill
      Last Post: 05-13-2010, 02:32 PM
    3. TORMACH CNC PCNC 1100 only $6800.00 ???
      By twocik in forum Benchtop Machines
      Last Post: 08-21-2007, 03:26 PM
    4. syil sx3 vs tormach pcnc 1100
      By ataxy in forum Benchtop Machines
      Last Post: 03-16-2007, 11:51 PM
