Results 1 to 2 of 2
Thread: G Code to tap 8/32
    Registered carlboe's Avatar
    Mar 2008
    G Code to tap 8/32
    I need to tap some 8/32 hole and I'm trying to write code and I'm having trouble. Can some one help oh it will be in alum. 1/2 though holes. I'm using a Tromach 1100 with a tromach head the small one 0-1/4
    Carl Boe
    Feb 2007
    TC or reverse head ?
    If you using a TC head this is how my code looks... Note my cam program at the moment doesn't support tapping, so a drill mop with custom script was needed. A few duplicates of the code I haven't had time to work out, but does work 100% every time for me. Tormach shows examples how the codes should look for both reverse and TC, check that out. This is for a 8/32 tap
    ( .164 Tap Nest )
    ( T18 : 0.164 )
    M09
    M998
    T18 G43 H18 M6
    M3 S500
    M08
    G0 Z0.1
    G0 X0.875 Y0.0
    G0 Z0
    M3 S500
    G4 P4
    G1 Z-0.5 F15.625
    M4 S500
    G4 P0.5
    G1 Z0
    G0 Z0.1
    (then on to the next hole)
  1. Replies: 4
    Last Post: 03-29-2011, 09:39 AM
  2. fanuc program code vs. Haas code
    By sixty8frbrd in forum Fanuc
    Last Post: 03-10-2011, 10:05 PM
  3. Converting Fanuc G code to Seimens 840D G code
    By Jasbinder in forum Siemens Sinumerik CNC controls
    Last Post: 02-20-2011, 11:02 AM
  4. Replies: 8
    Last Post: 12-15-2010, 03:32 PM
  5. looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft
    By troyswood in forum Ability Systems - LPT Indexer and G-Code
    Last Post: 12-24-2006, 10:21 PM
