Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: Incorrect pocket diameter
    Apr 2011
    Hi folks,
    My name is Terry, I'm a fairly new member with my first post, just been trying to read and learn so far.
    Posting because of a newbie problem that is puzzling me. I have an 1100 and have been trying to use the Newfangled Wizards to drill and then circular mill some holes in 6061 Al, but the size doesn't come out correctly. The operation seems to go OK, I drill to .250 diameter, then using a decent quality .250 4 flute carbide mill I circular mill to a desired diameter of .770, but the hole only opens to
    .722? I do not have any tools in the tool table except # 1 is an indicator, so I'm accepting the default in the wizard of tool # 4, setting the diameter to .250 and 4 flutes. When I get to the second page of the wizard I set the pocket diameter to .770, then set some very mild step over and step down numbers?
    I'm don't have a clue what I'm doing wrong, since I'm new at CNC, any help would be appreciated.
    Terry
    Jun 2006
    Stavanger, Norway
    I think as a first step it would help if you post the G-code.
    Phil
    PS: I mean on the forum.
    Apr 2011
    Phil,
    Thanks for the reply. Since I was trying to run a program for 15 holes, and it would be a little long, I ran the wizard this morning for just one pocket over a pre-existing hole so I didn't have to drill. Below is the code generated by the wizard, the requested pocket was 0.785, the measured pocket was 0.736.
    I set it up for 50% stepover and 0.06 step depth to a final depth of 0.28.
    Terry
    (Program Posted for Aluminum )
    G0 G49 G40.1 G17
    G80 G50 G90 G98
    G20 (Inch)
    (***** Circular Pocket *****)
    M6 T4(TOOL DIA. 0.25)
    M03 S4000
    M9
    G00 G43 H4 Z0.25
    X0 Y0
    G01 Z-0.06 F4.3
    G3 Y0 X0.13 R0.06 F8.6
    Y0 X-0.125 R0.125
    Y0 X0.25 R0.19
    Y0 X-0.25 R0.25
    Y0 X0.2675 R0.2588
    Y0 X-0.2675 R0.2675
    X0.2675 Y0 R0.2675
    Y0.1338 X0.1338 R0.1338
    G00 Z0.25
    X0 Y0
    G01 Z-0.12 F4.3
    Y0 X-0.125 R0.125
    Y0 X0.25 R0.19
    Y0 X-0.25 R0.25
    Y0 X0.2675 R0.2588
    Y0 X-0.2675 R0.2675
    X0.2675 Y0 R0.2675
    G00 Z0.25
    X0 Y0
    G01 Z-0.18 F4.3
    Y0 X-0.125 R0.125
    Y0 X0.25 R0.19
    Y0 X-0.25 R0.25
    Y0 X0.2675 R0.2588
    Y0 X-0.2675 R0.2675
    X0.2675 Y0 R0.2675
    G00 Z0.25
    X0 Y0
    G01 Z-0.24 F4.3
    Y0 X-0.125 R0.125
    Y0 X0.25 R0.19
    Y0 X-0.25 R0.25
    Y0 X0.2675 R0.2588
    Y0 X-0.2675 R0.2675
    X0.2675 Y0 R0.2675
    G00 Z0.25
    X0 Y0
    G01 Z-0.28 F4.3
    Y0 X-0.125 R0.125
    Y0 X0.25 R0.19
    Y0 X-0.25 R0.25
    Y0 X0.2675 R0.2588
    Y0 X-0.2675 R0.2675
    X0.2675 Y0 R0.2675
    G00 Z0.25
    M5 M9
    M30
    hub
    hub is offline
    Sep 2010
    Finland
    I'm fairly new also.. But it could be a number of things.
    - Tool offset value on diameter (wear compensation) wrong
    - Backlash
    - Wrong settings for lead screws (steps/inch or mm)
    - Among probably a few other things
    What controller/controller software are you using? (The 1100 doesn't ring a bell)
    Are the dimensions wrong only when doing a circular pocket?
    Hub
    http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html
    Apr 2011
    Hi Hub,
    Thanks for your help. I am very new at this, but the machine is a Tormach PCNC 1100 with Mach 3 (Tormach version), and is essentialy brand new. I did not set any tool compensation, and looking at the offsets page shows none being used. If this is not the right place to check it, I would appreciate being corrected! I have not done any other projects other than a couple of canned programs such as the roadrunner from Mach 3 and one I downloaded called Knight, which is a 2 1/2 D profile of a horse's head with a 1/16" ball mill, and it looks fine. I don't believe there is significant backlash, since the mill uses ball screws, is new, and it repeats to position very well when using a probe.
    Terry
    hub
    hub is offline
    Sep 2010
    Finland
    I would check each axis anyway. Tell it to move a distance and measure if it did move correctly. Then, move it back, and measure if it returned to where it started. If not, there is some backlash.
    Also, do some other stuff, square pockets, circles, text, and so on. And measure if they are correct within tolerance.
    Hub
    hub
    hub is offline
    Sep 2010
    Finland
    Also, looking at the gcode.. the R0.2675 x 2 = 0.535 dia. Adding the tool dia (0.25) to that should make a 0.785 hole..
    Registered R.DesJardin's Avatar
    Aug 2008
    holes
    Not using a reground end mill are you?
    RAD. Yes those are my initials.
    Idea, design, build, use. It never ends.
    May 2007
    I do not know about the final size but the first few lines should be causing the control to complain.
    Ignoring the Z moves.
    You first position at X0.0 Y0.0
    Then a G3 arc to X0.13 Y 0.0 but you want it to use a radius of 0.06
    You need a radius of at least 0.065 or 1/2 of the linear distant between the starting position and ending position.
    Same thing on the next line with the F0.125
    Code:
    G00 G43 H4 Z0.25
    X0 Y0
    G01 Z-0.06 F4.3
    Y0 X-0.125 R0.125
    Apr 2011
    Holes, the end mill is new, it's an Atrax from ENCO.
    Andre', Is this a bug in the wizard, or am I not entering something correctly?
    Hub, I guess the same question applies to your comment about R0.2675?
    Terry
    Apr 2011
    All,
    How to say this?? First a sincere apology for wasting everyone's time. The endmill turned out to be off size.
    After Holes question about re-ground, I took another look and the mill is strange, at least to me. It measures .2020 which doesn't translate to anything that makes sense to me, it would be 5.13 metric, closest fractional would be 13/64, but it's a little smaller than that?
    I have never purchased a used endmill and have never had one sharpened, so I'm at a loss to figure out what I've got here?
    Re-cutting the code with a proper .250 endmill results in the correct .785 pocket, so I guess that ends the questions anyway.
    Again, I apologize for not checking it physically before posting the question.
    Terry
    Registered BobWarfield's Avatar
    May 2005
    That endmill was out by a lot--did you purchase it on eBay by any chance?
    I've gotten some that were out that much from eBay and advertised as new. They were regrinds or rejects one.
    Still, it can be surprising how often even name brand endmills are off a little bit in diameter. Some manufacturers make a real point of emphasizing theirs are not. The standards are pretty lenient.
    If accuracy matters, I like to measure the EM rather than taking the manufacturer's word for it.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  • Page 1 of 2 12 LastLast
    1. Incorrect STL dimensions
      By Smooth90 in forum GRZ Software- MeshCAM
      Last Post: 12-27-2010, 08:20 PM
    2. Incorrect arc moves
      By MadPickinSkills in forum HURCO
      Last Post: 09-23-2010, 02:17 PM
    3. Shaft Diameter, LeadScrew Diameter, Motor Torque?
      By cnc-newb in forum DIY CNC Router Table Machines
      Last Post: 12-24-2007, 03:51 PM
    4. Shaft Diameter, LeadScrew Diameter, Motor Torque?
      By cnc-newb in forum General Metal Working Machines
      Last Post: 12-14-2007, 10:25 PM
    5. V19 incorrect toolpath
      By Castle1 in forum BobCad-Cam
      Last Post: 07-02-2004, 11:10 PM
