Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: delrin slitting problem
    Jun 2008
    Hi Guys,
    I've been a longtime lurker and have posted a few times (even though count says 1) and would like to introduce myself and ask a question.
    I'm a hobby machinist/woodworker and bought my 1100 about a year ago, it was a school mill that was never powered up. I made my own stand from Tormach's plans. It was pretty straight forward and I would recommend the project to anyone with even basic woodworking skills. I will try to do a write up on the stand later and show what I changed and what I would do different next time. Anyway I am slowly making progress into the CNC world and appreciate all of the knowledge available on this board.
    To my problem, I having a little trouble with delrin. I'm trying to use a slitting saw to cut strips out of .5" x 9" delrin block mounted vertically in my vise. I was using a 2.75" x .036" saw with 56 teeth, 800 rpm and 35ipm, conventional cut. (gwizard was showing 60ipm but I started slower) The cuts start out fine but the blade wanted to climb up and eventually snapped.(x2) It was machined dry but I was using an air hose to clear chips.
    I'm thinking about trying a 3" x .050" saw with 30 teeth and maybe 2 passes.
    Anybody have any recommendations?
    Thanks,
    John
    Dec 2010
    uk
    delrin delrin
    try acetal i find its better to work with
    Jul 2005
    I always thought Delrin was acetal.
    I think you are going way too fast. Delrin is a thermoplastic and it melts quite readily. You probaly had chips jammed between the teeth melting and gumming everything together.
    What you need is as few teeth as possible and run no faster than about 200 rpm while slathering on soapy water to cool and lubricate.
    Jun 2008
    Geof,
    That makes sense regarding the speed. I'll slow it way down and try the soapy water. Thanks for the tip.
    John
    Registered Don Clement's Avatar
    Jan 2007
    Running Springs, California USA
    For me Delrin and Turcite machine well. I use a two flute high helix HSS endmill to machine Delrin and Turcite on the Tormach at very high speed with excellent results, no cooling. Also machine Delrin and Turcite on my lathe at high speed. Chips are a contiguous long string. If cooling is used, it is cold air stream from a Vortec cold air gun. I haven’t used a slitting saw on Delrin or Turcite but part-off on my lathe using an Iscar Do-Grip carbide insert blade at high speed with excellent results. http://i72.photobucket.com/albums/i1...KDK1010Bar.jpg http://i72.photobucket.com/albums/i1...DoGripChip.jpg
    Perhaps your slitting saw is too fine a pitch and the long stringy chips can’t clear the fine pitch blade.
    Don
    Registered zephyr9900's Avatar
    Feb 2006
    Quote Originally Posted by Geof View Post
    I think that mackie67 was referring to the difference between Delrin, a homopolymer acetal, vs. copolymer acetal like Celcon.
    Randy
    Oct 2010
    Quote Originally Posted by john2532 View Post
    Hi Guys,
    Thanks,
    John
    I would also try some coolant or some light oil to keep the material from melting, always use a very sharp cutter with delrin,
    Delrin cuts great, if you can keep cool,
    Mar 2011
    UNITED STATES
    Delrin is acetal. Delrin is the brand name while acetal is the generic name. Acetal is the best machinable plastic. I buy it from High-Tech Plastics Works great, lasts long.
    Jan 2007
    Delrin and similar acetal plastics machine extremely well. Here are a couple of parts I machined from 5/8” Turcite X rod,( Boedeker Plastics : Turcite A, Turcite X Datasheet ) an acetal plastic similar to Delrin AF: http://i72.photobucket.com/albums/i1...f/TurciteX.jpg
    Machining of the Turcite X was done dry, no cooling on my lathe and Tormach mill at very high speed. I probably could have used the Speeder when using 1/16” endmill for milling the keyway slot as the maximum speed on my Tormach is 5.1K rpm.
    Don
    PS Randy: You think that acrylic chips are bright, Turcite X florescent orange chips covering the mill and lathe are quite a sight.
    Feb 2006
    I bet they are, Don. I've never machined Turcite X, but AF chips look like shaved chocolate to me...
    Randy
    Jan 2007
    Quote Originally Posted by zephyr9900 View Post
    Randy
    Randy,
    I agree AF chips do look like shaved chocolate. I used Delrin AF rod before finding Turcite A & X which I found were better materials than AF. Still have some chocolate AF stock next to the blue Turcite A and florescent orange Turcite X .The AF material seems to be like a fiber composite with fibers of PTFE woven throughout somewhat like fiberglass where the fiber structure is clearly visible, whereas Turcite is homogeneous.
    Don
    Feb 2007
    New Zealand
    Hi - Is your slitting saw razor sharp? If it was previously used on steel and has one edge more dull than the other, it will progressively wander off and snap.
    Acetal/Delrin are both free machining but slippery and resist the cut if a cutter is flexible and even slightly dull. You need good sharp side rake/clearance on a side/face slitting saw
  • Page 1 of 2 12 LastLast
    1. Need Help!- slitting saw on v23
      By skippyfix in forum BobCad-Cam
      Last Post: 11-09-2010, 03:32 AM
    2. Helicoil problem in Delrin
      By ranchak in forum Metal Working Tooling
      Last Post: 09-11-2009, 11:34 PM
    3. Programming a Slitting Saw
      By behindpropeller in forum Haas Mills
      Last Post: 06-10-2009, 05:53 PM
    4. Slitting Saw help!!
      By PoiToi in forum CNC Swiss Screw Machines
      Last Post: 10-09-2008, 02:10 PM
    5. Help with slitting saw
      By evena4 in forum General Metalwork Discussion
      Last Post: 08-23-2008, 02:09 PM
