Results 1 to 6 of 6
Thread: Table clearance to column at max Y travel
    Registered dbrija's Avatar
    Nov 2010
    I'm designing a subplate for my soon to be purchased PCNC1100, and I need a dimension. I may have overlooked it in all the documentation, but could somebody give me a rough dimension of the clearance between the table and the column when the Y axis is at the limit switch?
    Thanks!
    Danny Brija
    Registered Don Clement's Avatar
    Jan 2007
    Running Springs, California USA
    I just ran my 1100 to the negative Y-axis limit switch and the distance from the outermost bellows pleat looks like about 0.25".
    Don
    Nov 2010
    Quote Originally Posted by Don Clement View Post
    Don
    Thank you for that dimension. Looks like I won't be overhanging the back of the table near the column. I'll make a "U" to clear the column/bellows.
    Nov 2010
    Don,
    If you don't mind, how wide is that bellows?
    Jan 2007
    Quote Originally Posted by dbrija View Post
    Don,
    The Z-axis bellows are 2" deep and 9.75" wide
    Don
    Nov 2010
    Don
    Thanks again!
    1. TM-1 Table Clearance
      By hst in forum Haas Mills
      Last Post: 11-27-2009, 08:27 AM
    2. table rocks when reversing x travel
      By dahui in forum Shopmaster/Shoptask
      Last Post: 05-10-2009, 02:28 PM
    3. X2 with stiff table travel?
      By isaac338 in forum Benchtop Machines
      Last Post: 09-25-2008, 10:21 AM
    4. What's the max table and head travel on your X3 mill?
      By JMcDonald in forum Benchtop Machines
      Last Post: 12-21-2007, 01:36 AM
    5. X2 Column and Head with larger crossslide table
      By Rodm1954 in forum Benchtop Machines
      Last Post: 11-17-2007, 10:01 AM
