Results 1 to 8 of 8
Thread: The Incredible Little Tormach.
    Oct 2007
    Took on a job the other day that several shops had turned away.
    It was a high pressure pump body with a .625 bore with a depth of 2.8"
    The bore finish needed to be a 16um.
    The material was 1018 steel.
    I used a Kennametal Tenthset boring head and a 3/8" valenite boring bar to do
    the boring.
    After tweaking on a scrap bit I achieved a pretty good finish so I got on with
    the job.
    I made five parts and they only wanted four so I milled a quarter section away
    so I could see how the bore finish was right out of the Tormach.
    We measured it at 24um.
    I did have to hone the parts a bit to get the required finish but I was truely
    amazed once more at the capabilities of this little machine.
    I believe had I had balanced tooling I could have achieved the finish on the
    mill.
    So whats the next challenge?
    Regards
    Peter
    Attached Thumbnails Attached Thumbnails The Incredible Little Tormach.-pb010151.jpg
    Aug 2010
    U.S.A.
    Thanks for posting. If you don't mind - what was your boring setup?
    Oct 2007
    Boring set-up
    I used a Kennametal Tenthset boring head and a 3/8" Valenite bar.
    Feb 2009
    Quote Originally Posted by rwexec View Post
    the boring.
    the job.
    mill.
    Regards
    Peter
    A finish like that it is not a big deal to need to hone it thats pretty normal. a different tool would possibly get it for you. we do some 12 finishes with a custom made boring bar but it is very expensive.
    Oct 2007
    Done in one
    That's a strange finish requirement a 12 not at all common
    I am sure had I invested the money in expensive tooling I may well have achieved the what I was looking for but who wants to pay more for tooling than the machine cost itself
    An even less costly solution would be to use a different material such as Leadloy.
    The object is to get the part complete in one set-up without secondary operations, Done In One.
    When I get my fourth axis fired up I will be able to do jobs like this in just that manner.
    MBG
    MBG is offline
    Feb 2005
    uSA
    Did you thread mill the threads? just curious.
    Feb 2009
    [QUOTE=rwexec;847508]That's a strange finish requirement a 12 not at all common
    Implants
    Oct 2007
    Yes, I milled the threads.
    What kind of an implant needs to be honed?
    1. Need A Quote- RFQ - Urgent incredible turnaround needed
      By aadrew10 in forum Employment Opportunity
      Last Post: 09-10-2010, 04:57 PM
    2. Tormach Cnc ???
      By twocik in forum Tormach Personal CNC Mill
      Last Post: 08-24-2007, 09:22 AM
    3. INCREDIBLE Forum...but why no Link-Visited Indication?
      By polyNuker in forum Forum Questions or Problems
      Last Post: 01-09-2007, 08:44 PM
    4. Incredible application of home CNC
      By pstockley in forum Mechanical Calculations/Engineering Design
      Last Post: 03-30-2006, 06:35 AM
    5. Incredible pricing issues
      By Ferenczyg in forum Xylotex
      Last Post: 02-12-2005, 09:37 PM
