Page 1 of 4 1234 LastLast
Results 1 to 12 of 37
Thread: Sorry about the coolant
    Feb 2006
    Sorry to have to start yet another @#%* thread about flood coolant, but my current choice of coolant is killing me, I got this stuff from Napa because we use it at work in the bandsaw and it always worked well. But in the Tormach after 3-4 hours of heavy cutting the fumes from the stuff is burning my eyeballs out of my head. And it leaves a thick yellow coating all over the machine when it dries. It turns white like milk when mixed with water.
    So I want that cool looking clear stuff you see all over YouTube, is the "Premier 600 Synthetic Coolant" sold by Tormach clear when mixed with water? Do the fumes try to kill you? And does it stain everything? If so then what else is good? I saw a Mazak video and they were using this neat looking light greenish tinted coolant. From what I read it appears that a 20:1 ratio of Premier 600 would be about right?
    BlueFin CNC LLC
    Southern Oregon
    Feb 2006
    I use Koolmist #77 - works great for me. 4oz. to a gallon of water. Has a light blue color, no odor. I have cut aluminum, steel ,stainless and acrylic - worked for all of them.
    Jeff E.
    Registered R.DesJardin's Avatar
    Aug 2008
    Coolant
    I too am using the coolant from NAPA, but I am not having the burining eyes issues at all. I just bought 2 more galons of it. It does leave a film but it's easily cleaned using the coolant itself. We use the blueish tint stuff at work, want to say it's S-122 something. My buddy uses something just like the NAPA stuff in his Mori's, looks the same smells the same, 5 gallon bucket is like $125.
    RAD. Yes those are my initials.
    Idea, design, build, use. It never ends.
    Jul 2004
    Quote Originally Posted by Jeff E. View Post
    Jeff E.
    +1
    I find it works well for me. No fumes, it doesnt go off and smell. Its nearly clear and doesnt have any nastly chemicals in it from what I can tell. Overall very happy with it.
    David
    Feb 2006
    From what I read Koolmist #77 is for those spray mist things, are you using it as a flood coolant?
    BlueFin CNC LLC
    Southern Oregon
    Feb 2006
    Quote Originally Posted by BlueFin View Post
    Yes - It can be used for flood coolant applications as well.
    Jeff
    Apr 2008
    I've been happy with Blasocut 4000 for a couple of years. It will foam a bit if I forget to pay attention to the concentratIon, but get it back to the correct level and it's fine.
    I also use it in my surface grinder.
    Feb 2007
    Recommended from other members here on the forum, I'm 110% happy with my hangsterfers coolant. I bought the 777 because I'm mainly machining aluminum. I haven't noticed the yellow staining with this brand like the liquid ice stuff I was using. I wouldn't say it's clear, but very visible, however I think my concentration might be a little to high.
    my 2 cents
    Sep 2009
    +1 on the Hangsterfers coolant, I use the S-506 CF
    Registered 300sniper's Avatar
    Jul 2007
    hangsterfer's s500 here and am completely happy with it. no bad smells, no rust on the machine and no paint peeling off like i hear some other coolants cause.
    Jul 2004
    I may be a bit more sensitive to chemicals than others but I originally started with Hangsterfers S-506 CF and something in it bothered me. Just felt 'off' when exposed to it. The cool mist stuff doesnt bother me at all.
    David
    Nov 2007
    I have used nothing but Rustlick ws 5050 for the past 20 years. Never had any one in the shop complain.
    Ron
  • Page 1 of 4 1234 LastLast
    1. GPP - Coolant
      By mattpatt in forum SolidCam
      Last Post: 01-14-2010, 06:38 AM
    2. Umm... What do you do with old coolant?
      By Driftwood in forum General Metal Working Machines
      Last Post: 01-29-2009, 04:12 PM
    3. Umm... what do you do with old coolant?
      By Driftwood in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 01-22-2009, 04:54 PM
    4. Coolant and way oil
      By Cairns in forum Tormach Personal CNC Mill
      Last Post: 08-13-2008, 09:24 AM
    5. Coolant or No Coolant when turning....
      By Crashmaster in forum General Metalwork Discussion
      Last Post: 05-20-2007, 02:20 AM
