Results 1 to 11 of 11
Thread: Inside Square Corners
    Mar 2010
    I need to machine a few parts that will basically fit over a square hex, so will need to machine a inside hex with sharp edges. Machining most surfaces are straight forward, but now sure the best tools to use. Material will be AL and the hex size is about 3/4" across flats.
    Aug 2010
    you dont say how deep your going but you can try pre drilling the corners with an 093 dia. drill then use maybe a 1/4 endmill to rough the hex followed by a 1/8 endmill and finnally a 3/32. i would think there should be almost the same radious on a 3/4 hex
    Apr 2010
    Quote Originally Posted by hitachibos View Post
    Whatever size you decide to drill the corners, drill them on the exact center of the corner.
    This part is somewhat similar to a wrench. And a wrench does all of its work on the flats, and the corneers need not be a tight fit.
    Tom
    Registered holbieone's Avatar
    Feb 2007
    Quote Originally Posted by Magnum164 View Post
    you will need to broach the corners
    if it's a Through hole you can buy a hex broach , msc has them
    you could also remove the corners in the hex pocket
    Sep 2009
    Ive had to do a few 'square' holes on internal features before. I rough it to size best i can, then peck full depth with a drill stepping over a few though at a time and then finish with a hand file
    Jun 2010
    Re: Inside Square Corners
    If you want to run all the work on the mill and can't do the big hex broach, you could also get a small rotary hex broach and use it in the corners.
    Mar 2010
    I'll try and answer all the questions. This is not a through cut it's about .5" deep or so. I will probably go the route of cutting a hole on the center of the corners.
    never done any broaching, so not sure if you can do that on a Tormach or do you need a different machine. The idea is to do everything on the Tormach.
    Registered 300sniper's Avatar
    Jul 2007
    i found this video a while back and i have been wanting to try it with a tormach.
    if you machined away the rough hex shape only leaving the radius in the corners, with a properly ground tool, i don't see why this method couldn't be done on a blind hole as long as there is room to move the tool away at the end of the cut.
    [nomedia="http://www.youtube.com/watch?v=8gC4nbVB1-8"]YouTube- Rick CNC Cutting a Internal Spline[/nomedia]
    Mar 2010
    Thanks sniper. Actually one of my next projects also has a spline but I have been holding off.. But it will be a very small spline so I am sure there would be no problem doing that on the Tormach with it.
    Any idea where I can get a tool for that. I'll start looking/searching later tonight. Doing some masking for painting right now. Hate painting
    Jun 2010
    The tormach can definitely handle a rotary broach. For a selection of rotary broaches appropriate to that machine, I have seen them at littlemachineshop.com. I would buy the smallest hex one, broach the corners, then do the rest with an endmill.
    Sep 2008
    I've been using the 1/4" hex broach from littlemachineshop - it works great on my PCNC770 !
    1. square corners getting rounded off
      By SatanKlawz in forum General CAM Discussion
      Last Post: 06-29-2010, 09:33 PM
    2. Newbie- Square hole in square tube
      By bubblybill in forum General Metalwork Discussion
      Last Post: 09-20-2009, 11:18 PM
    3. Milling Tight Inside Corners???
      By Frogblender in forum BobCad-Cam
      Last Post: 05-28-2009, 08:21 PM
    4. Radius's appearing in square corners
      By simso in forum Mastercam
      Last Post: 01-02-2009, 11:10 PM
    5. How do you cut square inside coners?
      By Astroguy in forum Benchtop Machines
      Last Post: 08-15-2007, 09:11 PM
