Results 1 to 2 of 2
Thread: Reducing Spindle & Coolant dwell times
    WMD
    WMD is offline
    Jun 2010
    So I have my 770 all set up and running great, and have a lot of parts to run, and the m03 and m07 start delay is excessive.
    Does anyone know where to adjust the dwells for those macros?
    Mar 2008
    m3.m1s. Play only with the '3' (baseline dwell) and the '3.5', which is additional dwell proportional to the commanded RPM, and works out to about 3.5 seconds at 4000 RPM.
    All standard disclaimers apply.
  1. Spindle coolant what are you using?
    By carbidecraters in forum Fadal
    Last Post: 06-02-2012, 03:51 PM
  2. Balancing Main and Sub Spindle Cycle Times
    By danrudolph in forum CNC Swiss Screw Machines
    Last Post: 04-07-2009, 04:39 PM
  3. Coolant for HF Spindle ?
    By Greolt in forum DIY CNC Router Table Machines
    Last Post: 07-03-2008, 05:59 PM
  4. thru the spindle coolant?
    By cnc@52 in forum Haas Mills
    Last Post: 09-16-2007, 01:03 AM
  5. Through Spindle Coolant
    By Josh-PTP in forum Haas Mills
    Last Post: 02-28-2007, 12:42 PM
