Results 1 to 4 of 4
Thread: MACH3 - Limit N####
    Apr 2010
    MACH3 - Limit N####
    My mach3 only loads like 3500 lines of g code. Is there any way to change this number?
    Apr 2010
    In other words, my problem can be broken down into two questions.
    1. How do I change the way the exported g-code is numbered? For example if I want to change the current way ( N1-9999 )... to (N1-XXXXX), five digits instead of four.
    2. When I upload the code onto mach3 it only sees the first N1-4790 lines of code. MOST of my codes require more than 10,000 lines of code. Therfore I need to be able to upload atleast that much.
    Thanks!
    Mar 2008
    What are you using to generate your g-code? Can you turn N words off completely?
    Apr 2010
    using sprutcam, postprocessor, to generate. I think I figured it out, MACH3 on my pcnc1100 has the demo version installed.
  1. Need Help!- Home/Limit configuration in Mach3
    By ranju in forum DIY CNC Router Table Machines
    Last Post: 11-10-2012, 05:21 AM
  2. VSDEPI, Mach3 and limit switches
    By stevespo in forum Granite Devices
    Last Post: 02-18-2011, 04:59 PM
  3. Mach3 demo limit question
    By QSPSB in forum Benchtop Machines
    Last Post: 01-24-2010, 09:58 AM
  4. Limit switch config in Mach3
    By Richotech in forum Mach Software (ArtSoft software)
    Last Post: 07-27-2009, 01:16 PM
  5. Mach3 and limit switches
    By ZigMan in forum Mach Software (ArtSoft software)
    Last Post: 07-21-2008, 05:52 PM
