Results 1 to 4 of 4
Thread: Z-axis oiling defect
    Mar 2008
    I discovered last night that the intersecting holes that (should) deliver oil to the face of my Z gib do not intersect. The longer of the two isn't long enough... by about an inch. Is this a known/common issue, or just another "Oops!" confined to my machine?
    Registered Don Clement's Avatar
    Jan 2007
    Running Springs, California USA
    Quote Originally Posted by flick View Post
    I don't know if this is the case for my Tormach but I have been adding squirts of Vactra #2 way oil to the exposed Z axis ways in addition to using the manual oiler.
    Don Clement
    Mar 2008
    And may I assume that you are taking that step because they didn't seem particularly well lubricated? Might wanna check the gib, if you've already verified that your lines and fittings are free from leaks and blockages.
    Protip: before removing the gib, remember to rest the spindle nose on a block of wood.
    Jan 2007
    Flick:
    I won't bother. My Tormach has been working well for three years of heavy usage.
    Don
  1. Z-Axis Mod and One Shot Oiling Work
    By BobWarfield in forum Industrial Hobbies (Support forum)
    Last Post: 05-16-2009, 01:48 PM
  2. bridgeport z axis oiling
    By CNCPrototype in forum Bridgeport and Hardinge Mills
    Last Post: 11-16-2007, 10:21 AM
  3. Defect In Cast Iron?
    By Oldmanandhistoy in forum General Metal Working Machines
    Last Post: 09-01-2007, 09:05 PM
  4. X3: Way oiling? One shot?
    By InspirationTool in forum Syil Products
    Last Post: 01-22-2007, 07:18 PM
  5. Z not oiling!!!!
    By carbidecraters in forum Fadal
    Last Post: 07-07-2005, 09:26 AM
