Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 02-06-2010, 09:24 PM
johnh is on a distinguished road
implementing softlimits on 1100
I read all that I can but I keep coming up with this error.
When I press the "softlimits" button I've added to the interface I get this message if I am on the home switches of inside the machining envelope,
"Machine out of limits for softlimits activation"
The buttons call function is correct and matches the native Mach3 software.
According to artsoft all the settings are correct. Has anyone had success
implementing softlimits on the 1100?
jh
Old 02-06-2010, 10:11 PM
wvines is on a distinguished road
I have soft limits enabled and have not seen that error message. The button that I added to the screen triggers OEM-code 119. The LED indicator monitors OEM-code 23.
Old 02-07-2010, 12:14 AM
My button has the same codes. Care to share your home/softlimits setup in Mach? these are mine at the moment.
tired of bumping the switches and losing reference.
Old 02-07-2010, 08:27 AM
Mine are similar, except for the Y axis:
Y axis
Soft Max = 0
Soft Min = -9.2
When the machine is referenced, the Y and Z axis both Home to their max values, so their min values are negative. The X axis Homes to its min value, so its max value is positive.
Old 02-07-2010, 10:05 AM
cool, that did the trick wvines, thanks for the input!
For those of you with a PCNC 1100 HLF Ordnance Tormach PCNC 4 01-01-2010 05:51 PM
Anilam 1100 english bob General CNC (Mill and Lathe) Control Software (NC) 2 02-08-2008 09:12 PM
Softlimits in general HuFlungDung CamSoft Products 25 07-18-2006 11:36 PM
anilam 1100 tmt_92021 General Metalwork Discussion 1 07-09-2006 11:28 AM
Softlimits and Jog HuFlungDung CamSoft Products 2 03-08-2004 04:28 PM
