| Tormach PCNC Discuss Tormach PCNC machines here. |
Greetings, OK, those of you with a Shuttle Pro please test this plug in. I added 10 total custom macros, and I added a "Reverse Axis" option for Axis X-C. Let me know how the Reverse axis works, since there is another section of code that deals with jogging, but I think it is for something different, could be wrong of course. Remember to save out your current shuttle pro .dll Here is the link: http://www.machsupport.com/forum/ind...c,1220.80.html reply #88 (near the bottom of the page), has the New shuttle pro .dll The 10 custom macros work, just need a tester to varify the "Reverse" axis check boxes. scott
__________________ Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/ |
| Ok, I have attached, the debugged version II of the shuttle pro pendant for you if you wish to upgrade. It has be tested by the mach support community and all is working as it should. Total of 10 Custom Macro's now Added Independant Axis reversals for all 6 axis. Note: since I had to follow Arts numbering convention, the 6 extra macros are at the end of the 800 series list, this will bump down all OEM code indexes by 6, so any buttons you have assigned to OEM codes you will need to Re-assign. To install: you will need to open the zip file to your desktop and then if your running the standard Tormach install directory, navigate to it, and copy and paste the, "ShuttlePro.dll", into your plugins directory. DON'T double click the, "ShuttlePro.m3p", shuttle pro unless your running standard mach3 in its usual directory, if that is the case then double click the shuttlepro.m3p and it will auto install into the standard mach3 directory. scott
| shuttle pro/ video showing mpg | eloid | DIY-CNC Router Table Machines | 4 | 04-22-2009 10:23 PM |
| Shuttle Pro and Mach R3.042.020 | dsage | Mach Software (ArtSoft software) | 1 | 11-24-2008 04:27 PM |
| Shuttle Pro Problem | shane.vella | Mach Wizards, Macros, & Addons | 4 | 10-02-2008 08:11 AM |
| Shuttle In Problem | CountBraden | Haas Mills | 1 | 08-23-2008 11:57 PM |
| VF3 SHUTTLE IN FAULT | JACKOFTRADES | Haas Mills | 8 | 11-29-2007 10:23 AM |
