Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 06-16-2009, 09:15 AM
ag53711 is on a distinguished road
Spindle Door Latch
Dear Tormach Owners and Friends,
We have switched to a new improved spindle door latch design. This design replaces the rotary knob latch that was standard on previous machines. The cam action rotary knob was known to work loose under heavy vibration. The new latch is an over center draw latch and will not have this problem.
A latch upgrade kit is also available for existing machines as P/N 31217, http://www.tormach.com/Product_PCNC_maint.html. The cost is $15 and can be used on all previous machines.
With Regards,
Andy Grevstad
Applications Engineer, Tormach
Old 06-19-2009, 07:34 PM
zephyr9900's Avatar
zephyr9900 is on a distinguished road
Andy, there is no datasheet or instruction sheet on your website. Is the latch the large or small version? I'm trying to figure out whether it will cover the hole left by the cam knob (if indeed it's able to be installed in the same location). Thanks.
Randy
Old 06-21-2009, 04:36 PM
Hi Randy:
I'll see if we can't post instructions on the site later this week. I know they are sent with the kit.
To answer your question - yes, the kit comes with a plastc plug to cover the circular hole left by the old latch style.
Andy
Old 06-22-2009, 02:51 PM
Don Clement's Avatar
Don Clement is on a distinguished road
I just got the new latch kit today and there is a cover plug provided for the old latch hole. The new latch is mounted in a new position.
Don
Old 06-22-2009, 06:20 PM
Just installed the new spindle door latch kit. Very nice. The new camover latch works way better and is way easier to use when making tool changes. The only thing I changed was to replace the six metric philips flat head screws and nuts with 4-40 philips flat head screws and nyloc nuts with the addition of flat washers. Otherwise I would have used aerobic Loctite medium (blue) threadlocker and flat washers to the metric screws. It was an easy installation drilling six 5/32" diameter holes in the sheet metal using the supplied template.
Don
Old 06-23-2009, 01:00 AM
zephyr9900's Avatar
Andy and Don, thank you for the additional information. It looks like a good retrofit.
Randy
Tags
latch, pcnc 1100, spindle door, tormach, upgrade
Problem with door DMU 50V paris Deckel, Maho, Aciera, Abene Mills 1 04-12-2009 12:02 AM
Need Help!- Shaker Door spritzo WoodWorking 0 05-30-2008 05:26 PM
Need Help!- Need to get VMC 3016L through my door Mudge Fadal 3 03-21-2008 12:09 PM
Hinge/Latch hardware (OT?) Rance WoodWorking 5 01-03-2007 07:25 PM
Door interlock? Edster Fadal 9 04-05-2006 05:13 PM
