Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 06-15-2009, 02:36 PM
Freddy Bastard is on a distinguished road
probing
I found this nice probe. It exactly the same as the Tormach but for 500$ less... http://www.kelinginc.net/CNCMachineProbe.html
Old 06-15-2009, 03:45 PM
Al_The_Man's Avatar
I think you can get the Heidenhain KT130 cheaper than that.
Old 08-20-2009, 06:28 AM
bevinp is on a distinguished road
Freddy,
How well does the Keling probe work with the Tormach M3 controller? Is it simply a plug and play probe?
Al,
And is the Heidenhain KT130 compatible with Tormach M3?
Bevin
Old 08-20-2009, 08:07 AM
Finally, I got the one from Tormach. (More easy for me to order directly from Tormach as Tormach is already registered as one one of our supplier).
And yes, it's really a plug and play. Very easy to use and so much usefull. I can't work without it now...
Old 08-20-2009, 01:19 PM
Al_The_Man's Avatar
Originally Posted by bevinp View Post
Freddy,
Al,
Bevin
It is 5v npn open collector, never seen a Tormach so I cannot compare directly, the open collector output is the most common, the cheaper ones have simple contact closure.
Anyone have a list of measuring macro's?
Old 08-21-2009, 09:17 PM
Al,
Would you use a pullup resistor between the open collector and the signal wire? If so, assuming a 5V source on the signal wire, what size would you recommend? Or perhaps a better question is "what would be the target current draw?". I am assuming a target of about 10mA (with 20mA the maximum).
Thanks,
Bevin.
PS. Do you still have the same haircut?
Old 08-21-2009, 10:02 PM
Al_The_Man's Avatar
The spec states 800ohm
Pretty much
macro's for probing? REVCAM_Bob G-Code Programing 2 06-09-2008 08:17 PM
Probing? chunkymonkey General Metal Working Machines 2 04-01-2008 11:39 PM
Probing with Turbo CNC btalon TurboCNC 1 02-23-2008 07:19 PM
Automatic probing? MagooT LinuxCNC (formerly EMC2) 6 01-19-2008 11:56 AM
Probing geverhart WoodWorking 1 09-03-2004 02:41 PM
