| Tormach PCNC Discuss Tormach PCNC machines here. |
I'm looking for a big fly cutter. I'm going to be doing a lot of finishing/surfacing on 6061 aluminum bar stock. The largest I see at Enco with an R8 shank is 2.5". http://www.use-enco.com/CGI/INSRIT?P...PMAKA=225-3010 In the Tormach video they use a bigger one. Does anyone have any experience running bigger fly cutters in their Tormach and if so, where did you buy the tool? |
I have seen and used big flycutters that were a rectangular bar welded to a shaft. Usually holding 2 cutter bits at opposite ends of rectangular bar. On mills using a R8 collet large flycutters beat up the key / keyway holding the R8 collet. Also the pounding of the flycutter can shake and loosen bolts (also can loosen a part in a vise). With CNC sometimes a small Carbide Insert mill like (or a Face Mill with APKT Inserts) at a high rpm and high feed but light depth of cut can work very well. When feeds are over 20 inches per minute chips are flying, many times faster that a flycutter at a lower feed. Only real advantage of flycutters is tooling is cheap and cost to resharpen is cheaper if labor cost is low. |
| Making your own flycutter has got to be about as simple as it gets. Phil ![]()
| LETTERING HARDWOOD CUTTERS? AND PLYWOOD CUTTERS | andycorleone | WoodWorking | 2 | 12-12-2008 01:36 PM |
| Where to buy cutters | justCNCit | WoodWorking | 20 | 06-04-2008 03:41 AM |
| Need Help!- 1'' Fly Cutters | SKEETO | CNC Tooling | 2 | 04-17-2008 06:33 AM |
| How to tell what cutters go with what? | ZipSnipe | Benchtop Machines | 23 | 04-06-2006 01:55 PM |
| Cutters? | atemylunch | DIY-CNC Router Table Machines | 4 | 05-11-2005 12:56 PM |
