Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 06-04-2009, 09:27 AM
hdscarbro is on a distinguished road
Home/Limit Switch Upgrade
I'm just about finished upgrading the mechanical home/limit switches on our machine to proximity switches with solid state relays.
In my initial testing, the biggest variance that I've seen in homing Z is 0.0002. This is at least an order of magnitude better than what I was seeing with the mechanical switches. I'm waiting for some larger diameter flexible conduit and have not hooked up X, Y (or A ) yet.
The retrofit was straightforward, we only had to make two new trigger blocks for the Y axis and a new switch bracket for X. The new electronics (transformer, terminal blocks and relays) fit in the left side of the cabinet. If anyone is interested, please let me know and I'll post a parts list and some photos showing how we did the upgrade.
David
Old 06-04-2009, 11:22 AM
titchener is on a distinguished road
David, can you give the parts numbers and approximate cost for the proximity switches you used?
Thanks,
Paul T.
Old 06-04-2009, 12:14 PM
I used (qty 5) PMW-0P-1H switches from Automation Direct at $38.00 each. Each axis needs a relay, I used (qty 4) 682-2322 from Allied Electronics at $14.44 each. To power the switches and relays I used (qty 1) 831-0231 power supply from Allied Electronics at $42.00.
Old 06-04-2009, 01:36 PM
David C. Allen's Avatar
David C. Allen is on a distinguished road
Hello David
Why was a relay required? I was wondering if you could have driven the limit's from the switches directly.
Edit:
After looking at the wiring diagram I understand the use of the relay's for the Z axis.
David
Old 06-04-2009, 03:20 PM
David, I didn't know you could get that kind of repeatability with a proximity switch. What kind of target are you sensing? Have you seen any temperature related variance? (ie hit it with a hair dryer and see if it still repeats).
Thanks,
Paul T.
Old 06-04-2009, 08:36 PM
The target of the proximity sensors is the square edge of a rectangular block. This what tech support at Automation Direct suggested that I use. For X & Z, I flipped the switch ramps over and am using the back sides of them.
I haven't tried any temperature testing. I'll try a little heat on the electronics and let you know the results.
Old 01-06-2010, 05:33 PM
jestism is on a distinguished road
This sounds exactly what I need to solve my switch solution (you can see information on my table setup and why my X limit switches are being replaced to dry out about every 3 days at this thread http://www.cnczone.com/forums/showth...340#post714340 )
If you are willing, would you please email me any and all information that I need to replace my current limit switch with this solution?
jestism@prexis.com
It would be "Greatly Appreciated"...
Thanks,
Mike J
David
Knowledge not shared is knowledge lost.
Old 01-06-2010, 06:44 PM
flick is on a distinguished road
Just thought I'd point out this thread for anyone who'd like to improve homing repeatability without investing in extra hardware. Standard disclaimers apply.
limit switch- home switch normd CamSoft Products 1 05-16-2008 07:56 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 08:58 AM
Is it possible to use the home switch as the limit switch as well? Darc Mach Software (ArtSoft software) 2 10-23-2005 01:50 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 06:58 PM
