Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 05-26-2009, 08:56 AM
R.DesJardin's Avatar
R.DesJardin is on a distinguished road
Question Tool Changes?
Not really a poll but how many tools do you guys use, on an average for most of your jobs/parts. I am finding I use between 4-7 different tools for the first op, although the is one part I make a few of I only use two. As some of my parts require 3 ops and additional tools to the 4-7 that I mentioned above.
I'm getting ready to make a pallet system where I can make 6-8 parts at a time therefore eliminating many tool changes per setup.
Old 05-26-2009, 12:39 PM
RTP_Burnsville is on a distinguished road
For my last few projects I would say 7-8 tools. The parts I have been making are fairly small and simple however most have several different size drilled holes that are needed.
As for tool holders there are never enough for either the mill or the lathe.... A pallet system sounds very cool.... Please share more on this idea.
Robert
Old 05-26-2009, 02:44 PM
BlueFin is on a distinguished road
I currently use around 3-5 tools per job, but that seems to be increasing as my abilities for more complicated parts increase. I do not own the TTS system, but I have a rack of R8 collets and a ER collet thing that mounts in the R8 spindle with about 12 different sizes of ER collets. I need to look into some kind of tool holders because setting a zero Z every single time I change a tool is getting real old real quick.
BlueFin CNC LLC
Southern Oregon
Old 05-26-2009, 03:28 PM
TTS holders
The TTS holders are the way to go. I set them once and just pick the tools I need when I program. I just need to get a half a dozen more.
Old 05-27-2009, 12:01 PM
David Bord is on a distinguished road
Very cool... I would think a pallet tool changer would be a great and simple option that would work for most guys and most jobs.
I usually use 3-4 tools on a part. I purposely limit the number of tool changes per job to save time.
David
Old 05-27-2009, 01:18 PM
300sniper's Avatar
300sniper is on a distinguished road
most of my parts require between 4 and 7 tools. i am limited on tts holders and of course every job requires different tools. this means i modify my tool table and set the heights for every job. when i get rich, i plan on buying a bunch of tts er20 holders
Old 05-27-2009, 02:05 PM
kevperro is on a distinguished road
They are pricey suckers. I'm trying to keep my designs to 3-4 tool changes per part. My designs are pretty simple though.
I think I'm going to buy the tapping head tomorrow. If you count that, I guess it adds another tool change to the equation.
Old 05-28-2009, 01:42 AM
elmhurst_motor's Avatar
elmhurst_motor is on a distinguished road
for the small parts i make using the high speed spindle i try to use just the one tool, for larger everyday work stuff i would use 3-4.
see link for an example of some small parts.
http://otiraminiatures.blogspot.com/
brad
Old 05-28-2009, 03:22 PM
Don Clement's Avatar
Don Clement is on a distinguished road
I use more than 40 different tools for my product on the Tormach. These tools include end mills, ball end mills, edge rounding end mills, drills, slitting saw, threadmill tools with internal and external inserts, each insert for a specific pitch for many pitch sizes metric and imperial, Procunier 1E tap head with interchangeable QD taps for both blind and thru holes (2-56UN, 4-40UN, 6-32UN, 8-32UN, 10-32UN, 1/4-20UN, 1/4-28UN, M6-1 ISO), countersink tools, several boring heads fixed for specific diameters, edgefinder tool, centerfinder TDI tool, and master-tool-height TDI tool. All these tools are mounted in the TTS toolholders from custom made to ER collet types.
Don
Old 05-28-2009, 04:55 PM
keen is on a distinguished road
Hi - I do toolmaking and so have hundreds of different tools. But I only have 3 ER TTS and usually manage with 2-3 tools per 'set up' - I use a master X/Y/Z wobbler and set lengths offline.
  #11   Ban this user!
Old 05-28-2009, 06:43 PM
levelzero is on a distinguished road
I usually only use 3-4 tools per job. I plan things out as best as i can to eliminate tool changes. I have about 2- tts holders and use the same tool table for everything with a few spots that might change for custom jobs. This helps when programming as i know tool 9 is always a 0.500" 4 flute.
I've been day dreaming about a pallet system for the last year or more as a decent portion of parts I make are done with only one tool. A pallet system would greatly increase my abilities but as of yet i haven't been able to think of a clever way to do it.
  #12   Ban this user!
Old 05-28-2009, 07:49 PM
I design my parts so that each part is located precisely in a fixture using 1/8” diameter locating pins. The locating pins are located in the fixtures using drill bushings. In this way I don’t need to change tools but change the part in a fixture and using one tool per process on my parts. I also design symmetry into all my parts so that machining processes are as similar as possible. Also with symmetry in my design and using the same machining processes on the same fixtures, manufacturing errors and tolerances cancel out in my product design.
I use a Starrett TDI with a 0.200 range mounted in a TTS holder as tool #1. All tool heights are measured on a granite flat using Tormach measurement fixture p/n 30140, measured with a height gage then entered into the tool table. Tool #1 is used to measure the datum then the z-axis is zeroed. All tool heights in the tool table are referenced to tool #1.
Don
orient tool for tool change Hall effect? Luslugger CNC Machining Centers 0 04-24-2009 07:24 PM
Changing tool diameter in the tool offset screen Vern Smith Haas Mills 21 09-24-2008 10:54 AM
T slot tool post with drill bit tool holder brucesu1 CNC Tooling 0 06-09-2008 06:04 AM
Very slow tool change on Tool Room Mill Capt Crunch Haas Mills 3 12-21-2007 01:20 PM
G43.1 - Tool Axis Direction Tool Length Compensatioin EngTech Mazak, Mitsubishi, Mazatrol 8 12-06-2007 05:01 AM
