| Tormach PCNC Discuss Tormach PCNC machines here. |
#13
| Randy |
#14
| http://i72.photobucket.com/albums/i1...ettToolNo1.jpg The Starrett TDI is a Starrett n0. 25-511 mounted in a 1/2" TTS holder as shown. I run the TDI to 0.05" when zeroing and when measuring on the Tormach measuring fixture using a height gage. Repeatability is excellent. Note that AGD gages have a 4-48 threaded spindle and can accept different pads or feet. I have a ~0.3" diameter foot mounted as shown for zeroing tangent against a 1/2" diameter roll pin that I use for finding the datum on my 45 degree fixture. BTW thats not so easy with a a spherical probe tip. The 0.2 range of the Starrett 25-511 is also a good buffer for overtravel when zero is set at 0.05". Don |
#15
| Oooh, that's a totally different thing than my Last Word. I'm used to those being called dial indicators. In the words of the immortal Emily Litella, "Never mind..." Thank you for the picture, Don. I can see how that is great for setting height by adding the preload. 'Nuther thing for my shopping list. ![]() Randy |
#16
| http://i72.photobucket.com/albums/i1...t811Daedal.jpg Here is a picture of my center finding tool. It’s made from a Starrett No. 811 TDI mounted on a Daedal 15mm positoner. There is a 0.75” diameter boss at the top, which fits into the 0.75” R8 collet. Since repeatable height isn’t necessary for the center finder tool, TTS toolholder wasn’t needed. I used to have a Blake-clone co-ax centering tool but it broke. I think this center tool using the 811 TDI works better and I don’t have to run the spindle; just rotate the tool by hand. Don |
| orient tool for tool change Hall effect? | Luslugger | CNC Machining Centers | 0 | 04-24-2009 06:24 PM |
| Changing tool diameter in the tool offset screen | Vern Smith | Haas Mills | 21 | 09-24-2008 09:54 AM |
| T slot tool post with drill bit tool holder | brucesu1 | CNC Tooling | 0 | 06-09-2008 05:04 AM |
| Very slow tool change on Tool Room Mill | Capt Crunch | Haas Mills | 3 | 12-21-2007 12:20 PM |
| G43.1 - Tool Axis Direction Tool Length Compensatioin | EngTech | Mazak, Mitsubishi, Mazatrol | 8 | 12-06-2007 04:01 AM |
