| Tormach PCNC Discuss Tormach PCNC machines here. |
#13
| This is a good thread and something I have been considering doing myself. I have a machine I am producing that is a modern version of an antique woodworking machine. The old antique machines were all jeweled. I want to do the jeweling on them as well. I haven't had a chance to experiment with it yet, but i've read a lot about the jeweling practice. One interesting method was to glue a chunk of thick leather on a dowel and jewel with that and some polishing compound. I've also read of the pencil eraser trick. I do like the idea of a dedicated jeweling (polishing) machine tho. That type of machine wouldn't have to be quite so accurate either. Wade |
#14
| wwendorf - If I were planning to jewel large machine parts, I would want a pad much larger than a pencil eraser. The leather pad would work very well, and so would a big eraser that you cut and glue to a stick. For large parts, 1/2", 3/4", or even larger jewels would look good. I've even seen it done with a 4 1/2" grinder on very large sections of plate. I'm pretty sure you can still buy valve lapping compound at your local auto parts store. Get a can of coarse grit and give it a try. Since you want a slow spindle speed, you aren't going to sling much gunk very far. It is very abrasive, though, so cleaning the machine afterward does make sense (just to make sure you didn't sling the gunk anywhere important). Regards, - Just Gary |
#15
#16
| I did a test with my mixer and lava rocks and only run it 10 minutes. I could already see the burrs getting gone. I am designing my own right now. It will be the bottom of a plastic 55 gallon drum. Vibrator type. We'll see how that goes. For long parts, one guy on here built a trough style vibrator. Looked like it works pretty well. He has a video of it as well. http://www.cnczone.com/forums/showthread.php?t=52143
__________________ Lee |
#17
| This looks like a viable commercial solution. http://www.moore-tool.com/store/debu...ler-p-124.html As much fun as a big DIY project sounds, I need to make parts and some money and just don't have the time to monkey with the experimentation needed. I want to plug it in, pour in media and throw my parts in there and go. I just need to get them deburred and get the machining marks out so I can send them out for anodizing. Polishing MIGHT be something I try on just portions of the part. That was the reason I asked. I figured I could either bead blast the part, or vibratory tumble it and then move it back to the CNC machine to polish the portions of the part that will look real shiny. The contrast between a matt finish and the polished finish, covered with a clear anodizing treatment was the "look" I'm trying to achieve. |
#18
![]() Having said that, when I worked for a machine tool builder, we had some customers who needed to replace ball screws, gibs, spindles, and coolant pumps due to excessive wear from abrasion. These were on big VMCs with box ways, flood coolant and 40mm diameter ballscrews. One customer used our machines for grinding ceramics and had to replace gibs and ball screws every few years. Another did nothing but G10 and replaced coolant pumps every couple months and ballscrews every 18 months. The coolant pump still worked but the seals would start to leak. The ballscrews still functioned but the precision deteriorated. The graphite machining industry has specially equipped machines to deal with the abrasive nature of graphite. I should have qualified my too short answer by the ever-so-popular "it depends". If the machine were spending considerable time doing production polishing, I would bet serious money the precision of the machine would deteriorate rapidly requiring parts replacement within a year. For occasional use, some forethought into cleanup would go a long way towards minimizing potential long term damage. From my point of view, I can pay someone else to polish a lot of parts for the cost of replacing my ballscrews. |
#19
| Well.... I bought this little guy. It don't expect a super polished look but it should at least get me most of the way there for anodized parts. The tub is 19.75" x 15.75" x 15.5" which won't hold a ton of parts, but should allow me to do 5-10 at a time. I think I'm going to just try some manual buffing to get the polished look. If I get the parts most of the way there with the vibratory media, the final touch shouldn't take long with the right tools. At least it will be something to do while the Tormach is cutting parts. |
#20
| I polish 400 series stainless and aluminum on my $70,000 VMC and quite honestly don't worry about it. My machine is plenty accurate and I use 4" diameter hook and loop pads to get a mirror finish on flat stock. I run coolant during my polishing operations and I figure most everything probably gets suspended in the coolant. Will it wear something out? Maybe... Am I overly concerned about it? Not at all... If it works and makes money, then it's worth it to me. Would I recommend it to others? Absolutely as long as they know it's always possible to end up with unexpected long term results when using something in a way it wasn't originally intended to be used...
__________________ Gimpy aka 313 (three thirteen) The early bird may get the worm, but the second mouse gets the cheese. |
| Vibratory Finisher For Polishing Aluminum | HimyKabibble | Mass finishing equipment/media/stratigies | 23 | 12-11-2009 07:34 PM |
| Newbie- Abrasive grinding/polishing wheel for cnc mill. Possible? | ilya | CNC Tooling | 4 | 01-14-2009 12:16 PM |
| aluminum polishing tutorial | Tony-JL | Metal Finishing and Plating | 4 | 05-21-2008 07:09 AM |
| Polishing aluminum | jfong | General Metalwork Discussion | 2 | 05-12-2005 01:44 PM |
| Polishing Aluminum | creative_mind | General Metalwork Discussion | 23 | 03-23-2004 11:20 AM |
