| Tormach PCNC Discuss Tormach PCNC machines here. |
#13
#14
| Hi - I now only use rotating mechanical edge finders -The Starrett one is good - and a paper feeler for the Z. . On my elecronic height setter - sometimes I would get a persistant micro 'hair' of conductive material that gave false readings. Too dangerous for very accurate work. |
#15
| Thanks Guys, that was good information. After following the tips and links I will probably go for an electronic with overrun protection. But might buy both. That mechanical one from H Schmidt looks very good and and seems to have a better design than the Starrett so should perform at least the same. Thanks Michael. I found the debate (elsewhere in CNC) about exactly when the mechanical edge finders are indicating the correct position, to be a little confusing. The description provided by Starrett is a little ambiguous and probably gives rise to the two differing opinions. One is that the correct position is where the tip snaps into running true and the other is where the continued movement snaps the tip out of true. I am inclined to think it should be the mid position between those two points, with a bias towards the first. And the width of that gap would depend on the friction of the edgefinder tip to body (and spring pressure) and the friction of the tip rubbing against the workpiece. All of which would vary between edge finders, RPM, workpiece material and any lubrication. But I assume the gap would be small and therefore satisfactory for my needs. No doubt the expensive ($500+) 3D sensors would be excellent but too expensive for me. And the electronic finders seem to be fragile and most without reasonable cost of repair (but good for salvaging for other purposes!). But their apparent ease of use and consistency of errors that can be accommodated, makes me favour their mid price solution. Now all I have to do is chose the brand and the supplier. SPI told me their electronics don't have overrun protection. Fowler ads say theirs do and I am investigating the other common names. Thanks for the help. Bevin |
#16
It works better on a sharp edge with a clean vertical surface as this splits the beam into two and makes it easier to assess equal reflections from top to bottom surfaces. But it certainly does not provide accuracy within a few thou. |
#17
The laser would have the advantage of not needing a turning spindle. I found directions somewhere on the web that suggested a 1000 RPM spindle speed as the "right" speed for the mechanical edge finder. Tormach says the transition between center & offset is zero. If the part isn't perfectly smooth or if you have an angled surface that probably throws you off more than any error you make judging what to call centered. I've been using the step before it pops out as my reference. |
#18
| [QUOTE=kevperro;615304] The laser would have the advantage of not needing a turning spindle. QUOTE] You are right when you say that but since I find it difficult to see exactly where the centre of the beam is, I am not confident that when adjusted, it does not have an error. Consequently when I do use it, I am probably doubling the error. I do need to wear glasses so perhaps that may be adding to the dazzle. Others may not find the same problem. |
#19
| "I found the debate (elsewhere in CNC) about exactly when the mechanical edge finders are indicating the correct position, to be a little confusing. The description provided by Starrett is a little ambiguous and probably gives rise to the two differing opinions. One is that the correct position is where the tip snaps into running true and the other is where the continued movement snaps the tip out of true. I am inclined to think it should be the mid position between those two points, with a bias towards the first. And the width of that gap would depend on the friction of the edgefinder tip to body (and spring pressure) and the friction of the tip rubbing against the workpiece. All of which would vary between edge finders, RPM, workpiece material and any lubrication. But I assume the gap would be small and therefore satisfactory for my needs." The best way to obtain high accuracy is to make the cad/cam X/Y axis the part centre line, not the edge. and set the work or stock up central. that means you zero on wobbler spin "out' and do the same on the opposite side, It is very repeatable. and enter half the value in that axis dro - same for other axis. This is very accurate - you can be in position better than a half thou. |
#20
| "The best way to obtain high accuracy is to make the cad/cam X/Y axis the part centre line, not the edge. and set the work or stock up central. that means you zero on wobbler spin "out' and do the same on the opposite side, It is very repeatable. and enter half the value in that axis dro - same for other axis. This is very accurate - you can be in position better than a half thou." That sounds good. Since you are doing two opposing contacts you are automatically compensating for the diameter of the contact pin as well as for any consistent error in the technique. And if you can accurately measure by micrometer the actual width of the workpiece then you will be able to determine the actual allowance you need to make for those occasions when you can only contact one edge. As we say is Australia.. "Bloody good mate". And the more times you do the two side contact and check the actual measurement, the better average allowance you can determine, even get differing average allowances for different materials. And as the edge finder gets older and has altered characteristics, the two side technique will continue to compensate. As my kids would say.. "Cool". And sometime when I was a kid I think we would say "Keen". |
#21
| Cheers - wish I had stumbled on this method years ago - so much unnessary grief trying to get high precision battling inconsistant errors. Here is a good double check process - worth the few extra seconds. touch face with steps, zero dro on wobble, up and across, down and do opp side. Divide DRO value by 2 on calculator - enter this value in DRO (check if it needs + or -). Now the double check. Zoom back to the first side and wobble - check it is the same as the value still on your calculator. |
#22
I believe it was a Fowler.
#23
I use the Fowler above. Works fine. Doesn't solve the problem of poor part design, layout or fixturing. You still need a bombproof process to ensure success. I use the method above of splitting the difference between sides with an oversize part blank if needed or dedicated fixtures for production parts with a known relative position touch off spot on the fixture (top, front, left) |
| Just IN- MIE Solutions looking for Resellers, Finders and Distributors | MIE Solutions | Product Announcements & Manufacturer News | 0 | 01-07-2009 02:12 PM |
| Need Help!- Electronic LED Edge Finder | drhaasmach | CNC Tooling | 2 | 12-20-2008 03:07 PM |
| electronic edge finder tips? | Rich05 | General Metalwork Discussion | 11 | 07-18-2008 05:27 PM |
| Need a good list of parts and help locating them. Finders fee for you!!! | jjvogre@aol.com | Want To Buy...Need help! | 0 | 05-25-2008 07:15 PM |
| Edge finders and techniques. | redbaron | DIY-CNC Router Table Machines | 12 | 01-04-2005 01:22 PM |
