Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 05-07-2009, 10:28 PM
justgary's Avatar
justgary is on a distinguished road
How does this thing work?
The post about the Duality Lathe made me go out and look for videos of it working. I stumbled on this
It is hilarious when you listen to the Chinglish script, but the machine is truly amazing. I have my own ideas about how it works, but let's hear yours!
Regards,
- Just Gary
P.S. If you can't understand the Chinglish, don't feel bad. I pity the poor guy who had to read the script with a straight face.
Old 05-07-2009, 10:42 PM
METALTEK's Avatar
METALTEK is on a distinguished road
How does it work
I believe the Z axis of the machine(Mill) hooks onto the lathe carriage and the X and Y axis of the mill table move the lathe itself so the cutter/carriage follows along the tool path. Simple but ingenious in my opinion. (how the duality lathe operates in my opinion)
300sniper's Avatar
300sniper is on a distinguished road
wow! my best guess would be it is all about the timing.
Old 05-07-2009, 10:56 PM
zephyr9900's Avatar
zephyr9900 is on a distinguished road
Polygonal turning is all about the RPM ratio of a flycutter vs. the workpiece. Many papers online on the subject. I've only seen it done by software until this video--they're using a mechanical linkage between the spindle and flycutter axis. Unless there is some kind of change gears involved, I vote for the software solution...3-lobe, 4-lobe, 6-lobe etc.
Randy
Old 05-07-2009, 11:56 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
This is correct. You can do the same thing with a standard Lathe, but the flats will be a Large Radius.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 05-08-2009, 10:46 AM
pete from TN's Avatar
pete from TN is on a distinguished road
Well now that is simply amazing.....
Looks like friggin' magic to me.... I am sure it is some kind of super precise timing to get the cutter to strike the work at the exact same position and time relative to the spindles axis. Very impressive. I seriously doubt that the duality lathe while impressive could even do any of these things shown in the video. You are looking at dual independent movements in three axes all in a precise timed coordination. The software must be pretty elaborate and I am sure equally challenging to learn.. man do I have lots to learn yet....peace
Old 05-08-2009, 01:18 PM
Andre' B is on a distinguished road
Some more threads on Polygon turning.
Polygonal turning
Cutting Hex On CNC Lathe With Live Tooling
The flats are not really flat but a short section of the flatish sides of an elliptical surface. The long axis of the ellips is defined by the size of the cutter disk and the short axis by the part size so the larger the cutter disk relative to the part the flater the flats will be. Downside is the part takes longer to cut since percentage of time the cutting edge is on the part also drops.
Did we do the right thing? Crispymetal-fab General CAM Discussion 4 04-23-2009 09:07 AM
Where do I put this thing? Sal@TKL General Metalwork Discussion 2 04-17-2007 11:25 AM
what is this thing for? bigal General Electronics Discussion 35 07-08-2005 08:05 AM
What's this thing for? Chunky General Metal Working Machines 11 07-02-2005 02:34 AM
What is this thing? And what 'exactly' does it do? DAB_Design Benchtop Machines 7 09-17-2004 04:42 PM
