Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 04-24-2009, 05:08 PM
bobs_charger is on a distinguished road
Tapping with the Tormach Tapping Head
So the other day I felt brave enough to mess around with tapping. I first air cut a cycle using G84 for the tapping. I noticed that the z-axis would retract before the head had reversed. Is this possibly because the tap was not in the metal to stop it? I also gave the tapping head a try. I don't like how the arm of the tapping head sits in the machine and will be machining some parts to make it more robust, and will post them later. No as far as my spindle speed and feed rates.
I do most work in metric units. So for tapping an M8x1.25 hole, i would assume that if my spindle speed was 100RPM then the z-axis feedrate would be 125mm per minute. Seeing that a pitch of 1.25 means that for every revolution you transverse 1.25mm. Am I correct in thinking this?
Newbie- Tapping Head jon_fallon Fadal 4 10-20-2008 09:13 PM
Tapping head or rigid tapping Gregory_C Syil Products 2 10-18-2008 01:49 AM
Tormach Tapping and Mastercam mattford1 Tormach PCNC 0 03-17-2008 11:10 AM
Rigid tapping or tapping head wildcat Industrial Hobbies (Support forum) 7 09-24-2006 01:08 PM
tapping head vs hand/cordless tapping machine.... InspirationTool General Metal Working Machines 6 09-12-2005 09:10 PM
