Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
  #13   Ban this user!
Old 04-17-2009, 10:03 PM
apeman88 is on a distinguished road
Interesting stuff... the 3M 4200. Looking into it... I'm thinking 4200 and 5200. 5200 for the first layers around the joint and 4200 around all the removable pieces. Thanks!!
  #14   Ban this user!
Old 04-18-2009, 08:07 AM
sharpshooter90 is on a distinguished road
The marine sealant is probably a solution for those whose machine is already set up and running. If I was just taking delivery, I would take the stand and have it sandblasted and then weld all the seams and have it powder coated. The Chinese like to use bondo as a sealer and cover it over with paint, but the kind of vibrations you get from a machine in operation will eventually crack this mix and once the coolant gets in, it spreads.
  #15   Ban this user!
Old 04-18-2009, 12:55 PM
kevperro is on a distinguished road
You may as well just build a stand if you where to go through all that trouble. The wood stand is about $250-$300 in materials, even with the epoxy fiberglass top.
  #16   Ban this user!
Old 04-24-2009, 04:03 PM
bobs_charger is on a distinguished road
I had the same problem you did. My machine was leaking and coolant would get on the ground. I didn't need to change out the coolant because it would leak out and I would refil, but anyways, what I did was cleaned the chip tray and cleaned the machine like new. All the potential joints that could leak I then cleaned with rubbing alcohol and used RTV silicon to seal it. Let it dry for a day and I have not hane anyproblems with it. I will mention I did use a good amount of RTV because I forced it into every concievible crack that could result in a leak.
Casters on Tormach Deluxe stand apeman88 Tormach PCNC 6 01-03-2008 07:46 PM
Deluxe Stand and Tormack 1100 and interference with holding fixtures ddixon Tormach PCNC 3 05-26-2007 09:15 AM
Flood Coolant Containment (Deluxe Stand) SarcasmOMatic Tormach PCNC 1 04-09-2007 11:16 PM
How Do You Like The Deluxe Tormach Stand? Willyb Tormach PCNC 3 01-31-2007 09:38 AM
Coolant for Tormach with deluxe stand? MichaelHenry Tormach PCNC 10 08-20-2006 11:49 AM
