Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
  #13   Ban this user!
Old 03-16-2009, 10:23 PM
justgary's Avatar
justgary is on a distinguished road
300sniper -
I could almost swear that I have also seen carbide threadmills in the MSC Big Book (for pretty much the same price), and they have a 35% discount on cutting tools going on right now. If so, you could save about $15 on one.
Regards,
- Just Gary
  #14   Ban this user!
Old 03-17-2009, 10:27 AM
300sniper's Avatar
300sniper is on a distinguished road
Originally Posted by justgary View Post
300sniper -
Regards,
- Just Gary
just about all the suppliers sell carbide thread mills. i hadn't seen one that could reach 1.5" deep into an internal thread until i looked at the micro 100 site.
thanks again for your post on making your thread mill. now i know it can be done if i do need something special. i need to start studying up on the hardening process. what grade drill rod did you use?
  #15   Ban this user!
Old 03-17-2009, 12:10 PM
thackman is on a distinguished road
Thanks for the info Gary that was just what I needed. I've been confused as to why commercial thread mills (single tooth) were often only listed for a single thread size and reading through this cleared that up. It's because of the tip radius changes w/ thread size. You would want want a much larger root radius on a 2" bolt vs #6 screw.
The multi-tooth indexable threadmills seem to be fairly common (and expensive) but I haven't seen many like this. Enco has a few but they only go down to .250 which is too large for 1/4-20. I checked Micro 100's site and it looks like their threadmills are between $50 and $200. Which is far to expensive for me to experiment with but certainly reasonable for production. I'm going to make a few and get the process down and if it works out I'm going to try making one or two for ACME thread forms.
Does it matter if the thread root is rounded or flat? Most of the illustrations I've seen show rounded roots but the Micro 100 mills have flats.
  #16   Ban this user!
Old 03-17-2009, 02:18 PM
justgary's Avatar
300sniper -
The first tools (smaller threadmill and a taper reamer) were made from water-hardening drill rod. The bigger threadmill is oil-hardening, but I quenched it in water anyway (it is small, and would have quenched about the same in oil). I switched to oil hardening to try to help control warpage during the quench. Ideally, I guess you would want to grind to size after hardening.
I have some old peanut oil I plan to use for quenching whenever I figure that it really matters. It should smell good, at least.
thackman -
The shape doesn't really matter, but you could argue that a rounded edge will be stronger than a sharp corner. If you are after maximum strength, you probably want to round them. Sometimes (like dirty conditions) you want a little extra room at the tips of the threads so the junk has a place to go.
Remember to post pictures!
Regards,
- Just Gary
  #17   Ban this user!
Old 03-17-2009, 10:40 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Very nice thread, thank you for sharing it!
Best,
BW
Need Help!- WANTED TO BUY John Spirek Want To Buy...Need help! 0 01-09-2009 12:40 PM
Need Help!- help wanted carlosmeza46 Mach Wizards, Macros, & Addons 0 06-22-2008 03:41 PM
Just wanted to know.. extrem89 Polls 2 08-28-2007 09:16 AM
I found this and wanted to make Machinists Aware CrazyMachinist CNCzone Club House 57 06-25-2006 07:20 AM
Help wanted. REVCAM_Bob Employment Opportunity 2 02-01-2006 05:04 AM
