| Tormach PCNC Discuss Tormach PCNC machines here. |
#13
I respectfully disagree also. For a couple of reasons. First... by taking a shallow depth of cut with a quick feed rate your not building heat in any single area of materail to work harden. Second...by taking a shallow depth of cut with a quick feed rate your not building heat from a heavey chip load. Third...If you have air your adding coolant (air) to both part and tool also re-moving cut chips from cutter path. (air is not needed but will help). If you have air you could rig up a spray mist or drip. Also you could just burshing some coolant/water on part works or a you could use a spray bottle...so flood coolant is not always needed and sometime is not worth it for the mess... |
#14
| Doesn't the coolant also provide lubrication thus reducing tool wear. Just a thought Phil
| Mild Steel on a cnc router? | trooper55 | General Metal Working Machines | 5 | 08-07-2008 12:43 PM |
| Cutting 1" Mild Steel | 3DSteve | CNC Plasma and Waterjet Machines | 14 | 06-14-2007 04:58 AM |
| Mild Steel | MBG | General Metalwork Discussion | 1 | 03-09-2007 04:20 PM |
| Plasma cutter for 3mm mild steel | DEEDEE | CNC Plasma and Waterjet Machines | 5 | 01-19-2006 05:25 PM |
| Machining Mild Steel | georgebarr | General Metal Working Machines | 5 | 06-29-2005 06:54 PM |
