Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 01-25-2009, 12:42 PM
BlueFin is on a distinguished road
Coolant Pan
Finished my flood coolant pan yesterday and have it all installed now. Will probably order the Enco coolant tank and pump unless something better pops up. I have a big steel job coming in a few weeks and wanted to be ready for it. The pan is 14 gauge sheet metal, I had a local fabrication shop shear and brake the major pieces then I brought it all home and finished cutting and welding it up. I basically copied the diminsions of the basic stand pan except mine is about 1 inch deeper, I wanted steeper angles on the side to ensure rapid coolant return.
ID:	74435   Click image for larger version
BlueFin CNC LLC
Southern Oregon
Old 01-25-2009, 01:01 PM
crushmundy is on a distinguished road
Red face QUESTION???
I WILL APOLOGIZE AHEAD OF TIME FOR THIS IS TO ASK YOU A QUESTION ALTHOUGH YOUR BUILD LOOKS GREAT. I HAVE A CINCINNATI MILCRON SABRE THE TOOL CHANGER WENT DOWN AND WAS WONDERING IF WE COULD CONTINUE TO RUN CHANGING TOOLS MANUALLY WITH A PAUSE INSERTED IN THE CODE AT TOOL CHANGE. ANY INFO YOU MAY HAVE WOULD BE HELPFUL AND WOULD THE INTER-LOCK DOOR CREATE A PROBLEM?
Old 01-25-2009, 02:06 PM
Uh, I think you might have posted in the wrong forum, this is a Tormach mill area.
BlueFin CNC LLC
Southern Oregon
Old 01-25-2009, 02:20 PM
my bad
Old 01-25-2009, 04:25 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Blue Fin, that's a great looking pan!
May I ask ballpark what the fab shop charged? I'm curious before I go charging down to my local fab with a similar request.
Will you be adding walls?
Cheers,
BW
Old 01-25-2009, 09:26 PM
BW
The fab shop bill for materials and labor was $137.00 plus $12.00 for two cans of spray paint. It took me two evenings after work to trim, assemble, weld and paint the pan. Then about 2 hours this weekend to rent an engine hoist for $10.00 to slip the pan underneath it. Oh, I machined four 3/4" inch blocks with a 1/2" hole in each one to raise the machine up off the pan, I had some scrap laying around for that. Because I didn't plan ahead back in September, the four mounting bolts that I bought originally were a 1/2" too short now. So I had to buy $8.00 in new bolts ( I got some slightly used 5" 1/2" X 7/16" bolts I'll make someone a heck of a deal on! )
BlueFin CNC LLC
Southern Oregon
Coolant...Which and why? ajl6549 General Metalwork Discussion 15 12-08-2008 09:02 AM
Coolant and way oil Cairns Tormach PCNC 9 08-13-2008 09:24 AM
Coolant?? WingNutz Mastercam 1 12-06-2007 11:55 AM
What to do about coolant? petriej General Metal Working Machines 6 09-29-2007 08:11 PM
Coolant or No Coolant when turning.... Crashmaster General Metalwork Discussion 3 05-20-2007 02:20 AM
