| Tormach PCNC Discuss Tormach PCNC machines here. |
I'm looking for a face mill. This one is on special in the current KBC tool catalog and it looks like a good deal. http://www.miltecusa.com/documents/F...tFlyer2007.pdf The R8 version in 1.5" is $216.75 and includes ten inserts, a couple extra screws and wrenches and a nice case. Most of the inserts are around $9-$12 each and they have round, square & octagon that all fit the same body. Looks very complete but wanted to see if anyone has any personal experience using them. |
The Tormach tool is made by K-Tool, which is very similar. Both K-Tool and Mil-Tec use very good carbide and are free cutting, but the Mil-Tec deal is much better. Are you running a full size Bridgeport or a Tormach type mill? I ran a 3 flute, 1-5/8" cut (2" OD) Octamill like the Tormach cutter on a 3hp Taiwan Bridgeport knockoff and it would cut a mountain of steel. Compared to a cheap TPG style facemill, it was like supercharging the machine. Do NOT use endmill holders that extend the cutting edge from the bearing that will react the force. That will make your machine vibrate louder at .050" depth of cut than it would be at .150" depth of cut when you use a collet and choke up completely on the mill. Dave |
| I'll be running aluminum and using the Tormach. Thanks for the input guys. I'd really rather support Tormach all other things being equal. I wasn't sure if their face mill was the K-Tools part or not so thanks for clarifying that. For the price difference, I think I'll go with David's suggestion and just support Tormach. |
I recently purchased some of the TTS Machinable Blanks from Tormach. They are only $16.50 each. I also got some round carbide face mill inserts and retaining screws. It was pretty easy to mill pockets in the blank to make my own face mill. The blank is 39mm diameter (same as the 1.50 face mill) and the centers of my inserts are spaced 1.200 apart so it cuts a 1.200 wide flat. I have only tried cutting aluminum with it and it works well, although the aluminum started to build up on the face of the inserts. It might cut steel better. Len <>< |
| I downloaded their entire catalog and I'll read through more information on the inserts. They probable have more options than I need or want. |
| I picked up 1 1/2 face mill from Iscar insert are $8/moded $10/polished The face mill works great HP F90AN-07 HELIPLUS 90° facemills using HP ANKT For roughing I picked up a shreadmill that was a bit of money but it sure can rip FRW SHREDMILL-Rough Profiling Tools. [url] I would never spend the time to make one as I know I could never get the feeds and speeds you could run at...But for the hobbies why not as you don't really care about performance Last edited by HMB3000; 01-17-2009 at 08:09 AM. |
#10
| I have had my machine up and running for over 2 years...it has paid for itseft 3 times over...I sold my monarch as I was not going to get inside before winter and I want a cnc lathe...also made about $500 ptofit on the sale |
#11
#12
| Ok... I bought the 1" version in the 3/4" shank size which I can convert to TTS. It included the ten inserts for cutting aluminum and was only $127 with the body. That is about the same price as just getting ten inserts and you get the body, case & extra screws etc... I also bought the Little Giant NK-2 for my home-made coolant tank which was on sale. |
| Face mills and cooling | TeleGuy | General Metalwork Discussion | 4 | 04-11-2008 07:13 PM |
| Valenite Pentagon Insert Face Mills | bgmnn | General Metalwork Discussion | 0 | 01-22-2008 04:03 PM |
| Face Mills? Which one to choose for a good finish on aluminum? | peter.blais | General Metal Working Machines | 20 | 08-25-2006 11:41 AM |
| Face Mills intstead of end mills | balal | General Metalwork Discussion | 8 | 07-01-2006 01:35 AM |
| angular contact bearings face to face?? | powerfade | DIY-CNC Router Table Machines | 2 | 06-19-2005 12:01 AM |
