Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 09-08-2007, 09:16 PM
Willyb is on a distinguished road
Which Face Mill to get?
Hi Guys
I am looking for some Tooling for my Tormach mainly a Face Mill and small End Mill (1") using the Insert technology. There are so many different types of cutting heads and even more Inserts that it is very frustrating trying to figure out which one to get. Most of my machining will be with Aluminum 90% with a small amount in Steel. Cost is very important to me but I also don't want to purchase junk. I have looked at the K Tools Face Mill which looks like it does a good job but it only accepts K Tools Inserts. With the Tormachs 1-1/2 HP Spindle Motor I would guess you would need a 1.5" to 2" Face Mill?
Would be interested in you thoughts on a good Face Mill Cutter & End Mill for my application with the Tormach CNC Mill.
Appreciate your help.
Willy
Old 09-08-2007, 09:43 PM
John3 is on a distinguished road
Happy with these
FOR ALUMINUM:
We've used Korloy Inserts with Profile & Grind for aluminum in Dolfa Face/shoulder mill holders.
Korloy Inserts are available from Travers.com tool company: TCGT 21.52 HI CARB. INSERT Catalog Number: 22-286-776
And I picked up the Dolfa holders from:
http://www.msdiscount.com/columnar.a..._site=STARTOOL
ALSO CHECK OUT:
We are currently considering other products as well. See details in thread:
http://cnczone.com/forums/showthread.php?t=42858 Contact DaveReagan for his info as well.
I like the idea of 8 edges per insert and the ability to use round/square/and octagon.
John
Old 09-09-2007, 12:10 PM
MichaelHenry is on a distinguished road
I haven't tried face mills yet but have used a 2" flycutter from Rotary Technologies that takes circular carbide inserts:
http://www.rotarytech.com/products.php
The inserts are expensive but you get multiple "edges" on each so the cost per edge is pretty economical.
They've worked well on aluminum and Delrin, which is all I've tried them on so far.
Mike
Old 09-09-2007, 08:13 PM
zephyr9900's Avatar
zephyr9900 is on a distinguished road
Mike, thank you for that link. The 2" flycutter is on sale for $29.95 (regular $90) including one insert. And it is .750" shank, so it looks like it could be made TTS-compatible. Have you modified yours for TTS, or just using it as is? They do sound like just the thing with their extreme positive rake.
Best regards,
Randy
Old 09-09-2007, 08:31 PM
Chuck Reamer's Avatar
Chuck Reamer is on a distinguished road
I wouldn't go any bigger than 1.5" for a face mill, make sure you go for a high positive cutter or you will have problems.
Instead of a 1" indexable, just run 3/4" or even only 1/2" cobalt rougher's. They are very affordable, can haul major a$$ and will last forever in aluminum. You would probably have better luck running a small rougher than an indexable endmill.
Live free or die
Old 09-09-2007, 10:34 PM
zephyr9900's Avatar
Chuck, would your advice be the same for the flycutter that Mike linked above? It looks very attractive to me, with a single highly positive rake insert and it is a balanced design.
The real machinists at work (I'm just an engineer so am a novice in the shop) use flycutters to surface stock. And I'm pretty sure they are never less than 2" swing.
I've tried facing aluminum stock with a roughing endmill before and was not happy with the results.
Best regards,
Randy
Old 09-09-2007, 10:59 PM
Best regards,
Randy
I just took a look and that fly cutter would probably work pretty damn nice, I don't think it would do anymore than .035 DOC max(on steel). Just knowing how the Tormach runs, in aluminum it would be really nice 4500, .005 per tooth feed and you would end up with a mirror finish. (only speculation here, I have never used one). I have seen carbide fly cutters like that before, I just cant remember who else makes them.
I sometimes use a fly cutter with HSS to face on aluminum or really light cuts on steel. I think the smallest I have is about 1" dia cut, but I run over 2" a lot.
Facing stock with a rougher wont work worth a $hit, but for stock removal you cant beat them, at least in a Tormach.
Live free or die
Old 09-10-2007, 12:52 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
could you mount a hertel facemill on a tormach ?
you can get them as small as 2" maybe smaller , they are truely a great mill for cutting aluminum , they work great for facing as well as profiling if the tool is running true
Old 09-10-2007, 10:09 AM
Randy,
So far I've just used it with the standard Tormach 3/4" collet, primarily to surface plastic and aluminum stock. Eventually I may try to set it up for TTS, but I haven't seen the need so far.
Mike
Old 09-10-2007, 05:41 PM
zephyr9900's Avatar
Originally Posted by dertsap View Post
could you mount a hertel facemill on a tormach?
As long as it has either an R8 or 3/4" straight shank, it would mount in a Tormach, dertsap.
Best regards,
Randy
  #11   Ban this user!
Old 09-19-2007, 06:25 PM
I have my tooling supplier bringing me in a K-tool, 1.25" with 3 inserts. We tried to find an Ingersol cutter that would work and didnt have very much luck.
After he took a look at the vidio on the Tormach website, he was impressed and they can get the K-tool no problem. I will try it out over the next few weeks and post some more infor on it, including cutter price and insert price.
Live free or die
  #12   Ban this user!
Old 09-26-2007, 10:05 AM
I finally tried out my K-tools octa mill, wow the salesman and I were amazed with it.
It is 1.25" with 3 inserts in a X20 grade. I ran it full cutter width in HTSR 4140. 1750 RPM, .075DOC with a 16.2IPM feed. Cut like butter, beautiful golden chips coming off. Machine didn't bog down at all and was very quite in the cut. Can do 2/3 cutter width .050DOC at 32.4 IPM with ease, thats about 550SFM, and a .006 per tooth.
I would not hesitate to go to 1.5" dia if I had to do it again, the machine could handle it no problem. I will also purchase a .75" dia end mill from K-tools when I have a big pocket for it. They can be ramped in at 25 degrees, I cant wait to try it out.
The other great thing was that the cutter body was only $165, with the inserts about $13 each (8 cutting edges). I don't know any other manufacture that sells body for that price, except for rotarytech. I looked into the cutters from rotary and would have had to ship and pay brokerage fees with every insert order.
We abused it for a while, and even stalled the machine out mid cut. Except for the stall that damaged one cutting edge on one inserts. There are no signs of wear even after the hot rolled scale and some P20.
After using an octa mill for my self I think it is the only way to go for a Tormach. I don't work for K-tools, just really impressed with the cutter.
Live free or die
Tags
laser machine
3" Face Mill in a Seiki 4VS? TZ250 Vertical Mill, Lathe Project Log 2 11-01-2006 12:18 PM
Face/Shell Mill Arbor Zumba General Metal Working Machines 5 05-20-2006 11:01 PM
Face Mill camtd PTC Pro/Manufacture 1 04-28-2006 07:51 PM
Indexable face mill ? Ken_Shea General Metalwork Discussion 4 09-28-2004 11:25 PM
Face Mill Recommendation Malph General Metalwork Discussion 3 09-23-2004 04:38 PM
