| Tormach PCNC Discuss Tormach PCNC machines here. |
| Tormach Rigidity Was wondering if any of you do heavy machining - steel etc - and know the machines weakest link. I imagine under heavy cuts flex of the vertical column,base to vertical column or head would allow cutter chatter. Going off my Syil x3 and allowing for the Tormachs heavier proportions I imagine a 1/2 inch HSS end mill cutting say Mild Steel at sensible revs and feed - might be at its limit at say 1/4 inc depths? If there is a weak link that lets the rest of the machine down/has anyone made mods to beef the machine up - or is the machine quite balanced in its proportions? welcome youre thoughts. |
| Maybe you have seen this, but just in case. http://www.tormach.com/mfg_database.htm There are 2 steel milling examples with technical details and videos. Phil
| Thanks Phil - Yes I've seen that - it seems about as ridgid as my manual Kondia (bridgeport type). Thats pretty useful! The 1/2 inch rippa cutter stage is impressive - not sure why it was faced with a 1/4 inch cutter though? I have just heard my Tormach will be here in NZ end of August - so I will soon know. |
| Milling rigidity question | pminmo | General Metalwork Discussion | 12 | 05-30-2008 02:29 PM |
| Tormach | ErnieD | Tormach PCNC | 5 | 05-01-2007 09:30 AM |
| Locking Quill & Splines for Rigidity | BobWarfield | General Metalwork Discussion | 0 | 08-07-2006 04:08 PM |
| Fadal VMC Rigidity for Machining Steel | kurbelgehause | Fadal | 9 | 03-23-2006 10:28 AM |
| machine rigidity | frankv | Mechanical Calculations/Engineering Design | 10 | 05-11-2005 08:30 AM |
