Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 07-24-2007, 02:19 AM
keen is on a distinguished road
D.Y.O Steel bench
Just heard my machine is on its way - probably thundering a cross the US in one of your massive truck/trailers as I write! So I better get my A into G with a stand.
I have decided to make a steel bench - the freight cost to New Zealand was the main factor. Also I have limited space and want a bench with heavy castors so that I can park the machine in a corner - see JPEGS. i would buy a stand if i lived in the US - but sadly (being winter here) I don't.
Anyway no point in making a bench if it costs too much! So I went to the scrap yard and scrounged some steel. And then scrounged some ply cover sheets - so far the cost is about $100 NZ.
I hope to post some pics of the finished article - thanks again to those who helped me in recent threads. Keen
ID:	41195   Click image for larger version
ID:	41196   Click image for larger version
Old 07-24-2007, 09:59 AM
philbur is on a distinguished road
Looks like an excellent start to me.
Don't forget to build in a good system for chip removal.
Regards
Phil
Old 07-24-2007, 11:40 AM
Al_The_Man's Avatar
A method I have used in the past is to bolt a 4" ABS toilet flange to the underside.
This creates a flush surface for cleaning the pan and also allows coolant to be drained.
A short length of 4" ABS can extend it down to a container etc.
Old 07-24-2007, 04:22 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Originally Posted by Al_The_Man View Post
....bolt a 4" ABS toilet flange to the underside..
Called a closet flange. Why? I don't really know......
Consistency is a good thing....unless you're consistently an idiot.
Old 07-24-2007, 04:29 PM
I picked up a piece of sheet metal for the top surface - and am thinking about
coolant drainage and swarf removal. Was thinking about bolting a flanged collecter underneath - thanks for the confirmation. Also, its hard to see but the delux stand looks like it has holes each side of the machine about 4" x 8" that not only drain the coolant - but act as a shute for swarf extraction?
If I am wrong about that would it be a good idea? and one side or both? I welcome your thoughts - and thanks for your time.
Old 07-24-2007, 04:43 PM
Studying the web info more.........it looks like the delux stand has a little 'chip basket about 3" x 6' that drops into a sealed below surface recepter? is this taken out for bulk 'swarf removal' or just filter cleaning? How does the drawer underneath operate - is it just a filter - or is it a swarf removal aid? - sorry to ask so much.
Old 07-24-2007, 04:57 PM
Al_The_Man's Avatar
'A closet flange by any other name would smell as sweet'
( with appologies to W.S.)
and one side or both? I welcome your thoughts - .
Just underneath with a rubber or silicone seal.
Old 07-24-2007, 09:00 PM
Hi Al - Sorry to be a pain - but i don't quite follow - could you elaborate.
thanks
Old 07-24-2007, 09:34 PM
Al_The_Man's Avatar
I have a spare here, it is just a simple flange that is mounted under a 4.5" hole takes 4" ABS, bolt it through from the top, if you use round head coach bolts it makes for non-snag attachment.
ID:	41228   Click image for larger version
Old 07-24-2007, 10:40 PM
Thanks for that Al - and for going to the trouble of the photos! Most appreciated.
Did you mean I should install a wire mesh filters on or in that fitting - so that only coolant and fines get through - or would you allow the coolant and the swarf (metal chips etc) to go down into a tray or settling tank. - making it a convenient place to sweep or brush excess swarf?
Old 07-24-2007, 11:24 PM
Al_The_Man's Avatar
Do what you find best, I usually do both, catch the swarf and I drain the coolant off, don't put a mesh filter on it, you will be continually unclogging it.
  #12   Ban this user!
Old 07-25-2007, 01:54 AM
Yeh - I have that problem on my manual machines. I found a steel flange shaped like your part in my junk box - but the hole is only about 1 1/2' dia - what do you think? Thanks again
New bench for a new SX3 Involute Syil Products 6 06-15-2007 08:12 PM
Steel bench for X3 keen Syil Products 31 04-19-2007 02:47 PM
bench top mil with Cat 30 or 40 spindle triump Benchtop Machines 1 10-16-2006 10:54 PM
X2 Stand or Bench RTP_Burnsville Benchtop Machines 4 06-10-2006 06:50 PM
My new work bench. xyzcnc General Metalwork Discussion 4 04-20-2006 12:16 PM
