Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 05-05-2007, 09:50 AM
ddixon is on a distinguished road
Deluxe Stand and Tormack 1100 and interference with holding fixtures
Question about Deluxe Stand and Tormack 1100
1. How close to the column can the back edge of table on the Tormach go, is the minimum distance zero?
2. With the Deluxe Stand what is the distance from the inside of the acrylic insert to the front edge of the table.
I am trying to figure out what size vise will fit on the 1100 PCNC with the Deluxe Stand.
Also it looks like the 8 inch rotary table motor would interfer with using the acrylic insert?
David
Old 05-05-2007, 03:32 PM
Don Clement's Avatar
Don Clement is on a distinguished road
Here is a picture of a Kurt D688 http://www.kurtworkholding.com/workh.../anglock_d.php mounted on a Tormach. Overhang in the rear is ~1inch. The hex shaft protrudes though a 1.25” slot cut in the acrylic shield. The Kurt D688 has 6.8” opening. See:
http://i72.photobucket.com/albums/i1.../PCNC_Kurt.jpg
Don Clement
Running Springs, California
Old 05-26-2007, 08:49 AM
*Registered User*
TT350 is on a distinguished road
Hi
The vice dosn't hit the column in the back?
Chris
Old 05-26-2007, 10:15 AM
Originally Posted by TT350 View Post
Hi
Chris
The Kurt D688 vise protrudes about an inch out the rear of the Tormach table when using Kurt D50-33A step keys (11/16 x 5/8) http://www.kurtworkholding.com/acces.../vise_keys.php mounted in the center T slot. In this case the vise can hit the column when moving to the last inch of positive Y travel. IMO, the advantages of the Kurt D688 vise (e.g. 6” jaw width, 8.8” opening, GrooveLock® jaw http://www.kurtworkholding.com/acces...roove_lock.php ,etc) far outweigh the one inch loss of Y travel. I liked the Kurt D50-33A step keys (11/16 x 5/8) so much that I mounted a 5X7 angle table on ˝” tooling plate with the vise keys mounted same as way as the Kurt vise. That way the vise and angle table can be easily interchanged and line up perfectly with X axis. Also the slot in the acrylic shield allows the vise to be loaded with the shield in place. see:
Don Clement
Flood Coolant Containment (Deluxe Stand) SarcasmOMatic Tormach PCNC 1 04-10-2007 12:16 AM
How Do You Like The Deluxe Tormach Stand? Willyb Tormach PCNC 3 01-31-2007 10:38 AM
Coolant for Tormach with deluxe stand? MichaelHenry Tormach PCNC 10 08-20-2006 12:49 PM
What do you think of the New Tormack PCNC-1100 Willyb Benchtop Machines 87 03-20-2006 10:31 AM
Workholding Fixtures hstanki Employment Opportunity 0 03-06-2006 01:35 PM
