Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 04-26-2007, 01:48 AM
kerryveenstra is on a distinguished road
G31 uses machine coordinates?
I have successfully connected a touch probe to the accessory socket, but the coordinates of a successful probing are not as expected. I do this:
g0 z0
g31 z-0.5 (probe downward)
After the probe trips, parameter #2002 is supposed to be the Z coordinate of the location at the time the probe tripped (section 7.7.12 of the manual). And so I expect this command to do nothing:
g0 z#2002
If the program coordinates are the same as the machine coordinates, then the result of the g0 above is just a *tiny* movement, probably correcting for the probe having overshot or having backed off slightly.
But if the program coordinates are not the machine coordinates, the command g0 z#2002 causes a downward movement.
1. Is this expected operation?
2. Am I using g31 correctly?
3. What is the best way to get the program coordinates of the probing?
Thanks,
Kerry
Old 04-27-2007, 02:45 AM
I've confirmed through the MDI in the Offsets screen of Mach 2 that G31 definitely returns its probe results as machine coordinates. I can program for machine coordinates (yuck!), except that the tool-length offsets won't be automatic. Unless there's another way to do this, I'll end up copying tool length info into the G-code program, and I'll always need to confirm that the work offsets are 0,0,0 before running the program.
I hope there is a better way. I'll post what I learn.
Kerry
FanucOM machine coordinates bcdnm Fanuc 5 11-22-2006 06:29 AM
Help - Problems with Z coordinates in g code Socalsurferx G-Code Programing 4 03-12-2006 05:12 AM
Sending the table to the zero coordinates? saturnnights Mach Mill 6 02-28-2006 12:07 PM
Help!! Problem With Z coordinates in G code Socalsurferx Mastercam 7 01-30-2006 12:24 AM
Coordinates modal and / for rapids HuFlungDung OneCNC 6 04-04-2003 10:42 PM
