Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 03-19-2007, 04:17 AM
kerryveenstra is on a distinguished road
Center "punch" for CNC mill?
I noticed while drilling a 7/64" hole that without a centerpunch's dimple, the drill bit wanders slightly, offsetting the hole. What is the trick here? Is there a kind of "CNC centerpunch"?
Thanks for any ideas,
Kerry
Old 03-19-2007, 05:53 AM
philbur is on a distinguished road
How about starting the hole with a center drill, or a shortened drill bit or even an endmill.
Phil
Kerry
Old 03-19-2007, 06:05 AM
Hursty is on a distinguished road
11.9.1 Centre Drill
Only use on turning centres to drill for tailstock centre location or for the specific chamfer angle.
11.9.2 Spot Drill
Before drilling with a twist drill, first produce a centering hole. This supports the drill body before the point starts to cut and act as a lead for a tap; an unsupported drill may not start concentric resulting in a hole out of position or a broken drill. The point angle of the centring drill is traditionally between 90o – 100o; a 90o angle presents the simplest solution producing a 45o chamfer with ease of programming.
11.9.3 Drilling (Twist Drill)
To maintain the accuracy of a drilled hole, after centering, use light feeds to produce a straighter hole than that when forcing the drill using higher rates. When drilling a deep hole (>3×D), for materials that produce continuous chips, the method used is a peck drilling or chip removal operation. Withdraw a standard drill after a maximum depth of 5×D; gradually reduce this depth to 1×D for deep holes. For extra deep holes reduce the speed and feed progressively to half speed and minimum of 0.025 mm/rev (0.001”/rev), the drill supplier normally provides formulae for these and other calculations. The following graph is a Guide to the expected diameter oversize in normal drilling operation.
Old 03-19-2007, 06:19 AM
soszi1950 is on a distinguished road
Smile
hi to position a hole accuratly it is advisable to use a centre drill or spotting drill first to a depth of say 3 mm.
The spotting drill usually costs a bit more but the life is much greater. (spotting drills are used to mark new holes from old parts or PCDS) hope this helps
Don
Quote
If the finest genius studies at one of our colleges, and is not installed in an office within one year afterwards in the cities or suburbs of Boston or New York, it seems to his friends and to himself that he is right in being disheartened, and in complaining the rest of his life. A sturdy lad from New Hampshire or Vermont, who in turn tries all the professions, who _teams it_, _farms it_, _peddles_, keeps a school, preaches, edits a newspaper, goes to Congress, buys a township, and so forth, in successive years, and always, like a cat, falls on his feet, is worth a hundred of these city dolls. He walks abreast with his days, and feels no shame in not `studying a profession,' for he does not postpone his life, but lives already. He has not one chance, but a hundred chances.
Self-Reliance
from Essays: First Series (1841)
by
Ralph Waldo Emerson
Old 03-19-2007, 10:13 AM
Thanks everyone. "Spotting drill" is what I'm looking for.
Old 03-19-2007, 10:42 AM
And in some tool catalogues you will never find "spotting drill", you will find "CNC spotting drill".
Just a hint that may save you some searching time.
Old 03-19-2007, 07:27 PM
SMW Precision is on a distinguished road
Kerry
Kerry, try screw machine drill bits. Shorter and much more rigid.
Ken
Kenneth A. Emmert
SMW Precision LLC
Spokane, WA
866-533-9016 Toll Free
Old 03-19-2007, 11:51 PM
Don Clement's Avatar
Don Clement is on a distinguished road
In lieu of a spotting drill or to use fewer operations, I use screw machine length drills with a 135* split point. The 135* split point drill does not wander as much as 118* drill without split points. Also solid carbide drill is more rigid than HSS.
Don Clement
Running Springs, California
Old 03-20-2007, 01:35 AM
holbieone's Avatar
holbieone is on a distinguished road
90 degree spot drills work nice
drill radius in depth + .005 will leave a nice chamfer on the finished hole
Old 03-20-2007, 02:43 PM
> screw-machine length drills with a 135* split point
As usual, a quality suggestion from Mr. Clement! Thanks!
When I first started looking through the Travers master catalog a few months ago, I was thinking, "why are there so many different kinds of X" where X was nearly anything that I was looking for.
I'm starting to understand why: there's a *reason*.
Yep, there they are, on p. 4. But no solid carbide versions. use-enco.com has carbide ones, as individual bits. (Hmmm... A 10-to-1 difference in price for different USA sources of the same size. More homework for me.)
Yes, those 90s do seem to be great for chamfers. That's just too tempting to ignore.
My research suggests that the angle of the spotting drill should be no less than that of the drill (although I've seen opinions both ways, I'm preferring the recommendation from a spotting-drill manufacturer.)
But since 135* split-point drill bits are available individually, I can try a few the next time I place an Enco order.
Kerry
  #11   Ban this user!
Old 03-21-2007, 12:53 AM
I converted a S&D HSS 5/8” diameter 118* drill to 135* split point using a model 750 drill doctor. I use the converted split point drill without a spotting drill. The drill doctor has a diamond wheel and also sharpens my solid carbide split point drills.
Don Clement
  #12   Ban this user!
Old 03-21-2007, 03:02 PM
wildcat is on a distinguished road
When buying your spotting drills pay attention to the overall length. Most of the ones that I have got have been really short and work great in chucks or collets. However, I needed some 82 degree spotters, had to get them from a different manufactor, and they are REALLY long. They chatter like nothing else in a chuck cause the stick way out. In a collet pushed all the way up they are fine. May end up cutting the excess off.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 01:15 AM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 10:53 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 10:33 PM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 10:09 AM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 11:54 PM
