| Tormach PCNC Discuss Tormach PCNC machines here. |
| Tormach Lathe?!? Why oh why won't Tormach make a nice CNC lathe? Not a flat bed...but a nice little 30* slant bed. Something that would have a 1.5" through bore and a high-speed spindle option. Think Wabeco 6000e high-speed...on steroids. Not a full-on production lathe...but more than just a retro-fit. Something in say a 12x36 size? Personally I have no desire for anything with up to 40" center to center...but maybe up to a 13" swing? The user could decide if they want to use gang tooling or a sweet little tool changer. It would still be a benchtop design...hopefully with a nice Tormach stand and an enclosure like the Wabeco. I have it kinda/sorta designed in my head, and some napkin sketches. It would be a pretty simple machine. A U shaped bed...a headstock assembly, and a 30* slant plate that bolts to the back to mount the x axis. A tailstock with pneumatic control would be nice and an air-operated chuck. I have already been working on a simple, elegant bar-feeder design that would work with most CNC'd workshop/hobby lathes. It's not brand-specific, but comes with adjustable legs to match the centerline of the lathe's bore. Sorry I don't have any CAD skills. I'll see if I can whip something up in Adobe to give you an idea of what I'm talking about. |
| Does anybody know how I can post a pic on here? |
| Here it is...I hope it worked. Please don't make fun of me...it took me like 15 minutes to make it and is my first Adobe Illustrator drawing, so... Last edited by 307startup; 02-14-2007 at 11:26 PM. Reason: mistakes in post |
| That would be nice, but I don't think that they are done refining the mill yet. Mike |
| Maybe this one will work Try this one... |
| The market is possibly not big enough. A CNC mill has a much wider appeal than a CNC lathe, just checking the relative traffic on the various forums will confirm this. Regards Phil
| wow...I guess it's so small of a market that people are CNC'ing their lathes just because they have the parts laying around. I understand it's not that big of a market...mostly because nobody has put anywhere near as much effort into an affordable CNC lathe as they have with a CNC mill. Just like GM thought there wasn't a market for the Camaro and Firebird...but it's amazing the response they got after they killed it...and again when they did the new concept car. I think that an affordable high quality CNC lathe would sell better than it is being given credit for. |
| Degree of confidence in a business proposition is often inversely proportional to the level of personal investment required. Go for it. Regards Phil |
| Small CNC lathes come up on eBay fairly frequently and fairly cheaply. Look for the Emco compact 5 and others. Personally, I expect I will do the lathe/mill trick eventually. -Jeff |
#10
| Great. Now you've got me thinking about lathes. For me, even a manual lathe would be good to have. (Am I allowed to say "manual" in the CNC Zone?) I just added another eBay search. It's time to start looking at the market for these things. |
#11
| Degree of confidence in a business proposition is often inversely proportional to the level of personal investment required. Go for it. Regards Phil Actually if I weren't up to my neck with a mortgage and car payment, and a personal business venture of my own I would consider this option. I've never been afraid to risk my own money for the sake of doing the "impossible". If I ever get the CAD drawings done, I'll show everyone a combination CNC machine that I have been spec'ing. It has a decent size work envelope (30"X by 20"Y by 20"Z) and incorporates a vertical mill with a horizontal mill that doubles as a lathe and live axis... Small CNC lathes come up on eBay fairly frequently and fairly cheaply. Look for the Emco compact 5 and others. Personally, I expect I will do the lathe/mill trick eventually. -Jeff The only problem with an EMCO 5 is that they are CNC mini/micro lathes...cool for training, not much use for most hobbyist use. Unless you are into turning zillions of .75" or smaller parts. I trained on one at school...the average guy is going to want to turn something in the 1"-1.5" range occasionally and even turn some bigger stuff...swing is important as is a larger thru-bore. Hobby equipment shouldn't mean toy...it should mean that it is capable of supporting the hobbyist's interests. |
#12
It weighs about 1200 lbs, and runs off 220v single phase. It's got a power 5C collet chuck, or a power 3 jaw chuck, and a 6 station tool turret. 0-4000 RPM software controlled spindle speed. I'm not sure the size of the spindle bore, but I'd guess at 1.25" - I know there is more room when using a 1" collet. The longest part you could probably comfortably turn is about 7" at about 4.5" diameter. And the diameter could go a bit larger with some inventive tool mounting... The Ah-ha retrofit controller isn't the greatest, but it works. Eventually I'll change it all over to Mach3, but probably not until one of the more expensive control boards goes... Dave |
| What have you made with the Tormach? | SND | Tormach PCNC | 3 | 02-23-2008 12:39 PM |
| Other Tormach uses | lal19541 | Tormach PCNC | 2 | 02-05-2007 12:52 PM |
| Tormach for Prototyping | allennella | Tormach PCNC | 8 | 01-05-2007 01:33 AM |
| tormach mill | brinmac | Benchtop Machines | 81 | 07-20-2006 10:59 AM |
| My Tormach Is Alive! | partsman | Benchtop Machines | 4 | 05-25-2006 01:59 PM |
