| Tormach PCNC Discuss Tormach PCNC machines here. |
FYI: Here is a link to the Vardex thread milling handbook. Includes a link to downloadable thread milling software G-code generator. http://vardexusa.com/vardex-pdf/Hand_Book_inch.pdf Don Clement Running Springs, California |
| I agee, if all of your threading is small size, then tapping is more cost effective than thread milling. Most of the many thousands of holes I thread are blind 4-40UN. For the small 4-40UN threads, I use a Balax forming tap with Procunier 1E tapping head on a manual mill. This should directly transfer to the Tormach when it is delivered in March. But I also have a need to tap blind large internal and external threads 3.25-16UN and M102-1 in 1/2" thick triangular shaped aluminum plate where thread milling should work great. Right now to make these large threads, I set up on a manual lathe using the reverse helix method and full profile inserts. Cost is more than thread milling inserts as a full profile insert is needed for each internal and external pitch along with an assortment of anvils for differing helix angle of a particular thread. Multiple passes are needed with the lathe. and I have to physically change two gears when switching from Imperial to metric on my manual lathe not just switch some levers... a real PITB. With thread mills the same insert will work on both internal and external threads. Thread profile is 100%. Although forming or roll taps produce a stronger thread in aluminum than a cutting tap because they forge the thread it is still not 100% thread engagement. No relief slot is needed with a thread mill and one can thread right up to a shoulder. Thread milling has many advantages and in some cases even less expensive. |
| I have gone ahead and sprung for the small thread mills for my Tormach. The results are fast, accurate, and luckily I have not broken one yet. I'm just crying about the cost of the tool. For larger holes and OD threads, milling them is the optimum solution, especially where the shank diameter allows some strength in the tool. --97T-- |
| Don |
#10
| recintly tried this to produce an odd pitch internal thread metric around 1.25"X5.5tpi did it with a double angle cutter in two passes part was aluminum makes nice threads for somthing you can't by a tap for I'v got a bunch of scrap nylon I try first to save materials My old Boss BPT has a caned cycle for spirel milling that work's great Kevin Last edited by Kevin Taylor; 02-10-2007 at 05:07 PM. Reason: spelling |
#12
here is the download link for both the lite and full version of tm gen software from vargus http://www.vargus.co.il/tm_down.asp?num=3&title=10 |
| Thread milling | wjfiles | General Metalwork Discussion | 2 | 01-08-2007 05:13 PM |
| 0M-Thread milling? | mikul | Fanuc | 1 | 12-06-2006 12:56 AM |
| Thread Milling 3/8-18 NPT | shawn | G-Code Programing | 13 | 08-26-2006 09:24 AM |
| thread milling | DavidC1949 | G-Code Programing | 2 | 03-30-2006 01:27 PM |
| Thread milling, can anyone help | jtrav | General CAM Discussion | 16 | 03-06-2006 03:25 PM |
