Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Tormach PCNC
Tormach PCNC Discuss Tormach PCNC machines here.
Old 01-31-2007, 06:52 AM
digits is on a distinguished road
Question about TTS and auto-toolchangers.
Hi, I am considering buying some TTS tooling for my mill, and ideally I'd like to be able to upgrade to an auto-toolchanger in the future, without losing all the constant Z benefits of the TTS system. How suitable is the TTS for an auto-changer - will tool holders simply drop out when the drawbar is released, or would they have to be pulled/pushed out?
Also, does anyone know what's special about the 'ATC' variant of the TTS system (see this press release http://www10.dcccafe.com/nbc/article...ticleid=343058) - does it just add an extraction groove, and will it be available to buy instead of the standard tool holders?
Cheers.
Old 01-31-2007, 09:59 AM
Don Clement's Avatar
Don Clement is on a distinguished road
For me and my Rockwell mill, the TTS tool holders don't simply drop out when the drawbar is released. I have to give a small tap on the drawbar with rawhide mallet to get the toolholder to release. YMMV.
Don Clement
Running Springs, California
Old 01-31-2007, 10:11 AM
68rustang is on a distinguished road
My Tormach is brand new but the TTS tool holders drop right out after just loosening the drawbar. Like Don said, YMMV. I am very interested in the "ATC" variant of the TTS.
Old 01-31-2007, 12:11 PM
Thanks guys - I've accidentally found the answer to my own question when doing a search on 'taper cutting' :
http://www.cnczone.com/forums/showth...616#post238616
Check out post #29
Old 02-01-2007, 05:40 AM
philbur is on a distinguished road
Take a look at this post, and possibly the whole thread.
http://www.cnczone.com/forums/showth...38422#poststop
Whatever toolchanger that is developed for the TTS it will need either to push or pull the toolholder out of the R8 collet, or at least have some means to slightly "spread" the collet on release.
None of my toolholders (11 - I think) fall out when the drawbar is loosened.
Regards
Phil
Cheers.
Old 02-01-2007, 06:40 AM
Regards
Phil
Thanks Phil - I had read that entire thread - the mods to the ATC versions make sense even to me! I'd agree that aligning the toolholders to the spindle requires a lot of accuracy, but I would have thought that if the tools were on the table, it should be quite doable. I will have to try picking up drill bits from the table in the chuck of my mini-mill!
At the moment, it looks like the High Tech Systems quick-changer is much easier to impement an ATC with, but the TTS looks sturdier, and has way more choice of chucks, collets etc, as well as the off-line tool-measurement and repeatable Z-offsets. It is also significantly cheaper!
Old 02-01-2007, 06:54 AM
Without some form of taper I think you will be on a looser. The TTS shank measures 19.04mm. The R8 is 19.05mm, with out allowing for any "collet springing". If you stack up all the various tolerances in the ATC it will come to much more than this. I think the taper would allow you to use relatively lloose tolerances (read cheaper solution).
Regards
Phil
Old 02-01-2007, 07:13 AM
Regards
Phil
Hmm, you're right, 10um is pretty precise I suppose if I were brave enough I could buy some TTS tooling and add a taper to it, but as the ATC variant is due real-soon-now and the other changer is being beefed up soon, I might just wait and see what both systems bring in Feb.
I am so,so sick and tired of swapping tools, re-measuring the Z and starting over again - it's going to be a frustrating wait!
Auto tool zero wildcat Mach Mill 30 10-08-2010 12:03 PM
auto feeder Syphonics Mechanical Calculations/Engineering Design 9 12-20-2006 10:14 AM
Auto Cad to Solidworks bennett71 Solidworks 3 09-19-2006 03:46 AM
cut single, cut auto and cut all??? fastolds BobCad-Cam 3 10-06-2004 09:15 AM
