- Collet Closer Bearing
Banned
Hi, When you close the collet closer with the lever on a pneumatic cylinder, does all the pressure is on the thrust bearing?
Could I use a through cylinder to apply pressure on the thrust bearing.
Jeff
- You may not post replies
- You may not edit your posts
Forum Rules
