twocik, section 2.1.1 of the manual says "Power required is 200 to 250 VAC, 50 or 60 Hz. Continuous current is below 15 amps, but a 20 amp breaker or slow blow fuse is recommended." You will also need 115V for the PC and other accessories.
I had to add 230V wiring to my garage. It uses a special double circuit breaker that draws from both hot busses in the box, instead of one bus plus neutral.
You could probably run the PC from the adapter you show.
Randy
