rdsi thank you, thank you, this may help a whole bunch. I will check it out. Hope I can translate it to the WJ200.
Full Re-Retrofit On My Blog...
I Somehow Obtained a Actual Tormach Lathe BOB for My Retrofit...
Everything is Going Well I Have Full Accurate Movement, I had to Change Some Proximity Sensors From PNP to NPN homing and limits e-stop all working as they should..
My goal "almost there" is that with Path Pilot just a couple small edits to the INI File and updating should be simple when the Tormach updates roll out as well as adding a Turret in the future.
My Issue Right now is I Trying to Figure Out the VFD Configuration and Adapt to the Hitachi WJ200 to the Tormach BOB, Tormach Uses An Emerson Commander SK VFD.
The VFD Configuration is the next to the Last thing on my list for the Electrical Side.. Then after little over 3 years and multiple configurations I can Finally get things finished up.
Most the Connections Are Self Explanatory Hooking to the BOB Hitachi. Just trying to Figure How They are Using the Emerson I.O. for the Speed Control. (do not really want to assume and let the magic smoke out) It is hooked up on the lathe differently then the Mill or I would just go to my 1100 and pull the settings.
B1, B3, B7, On the Emerson Are In Question.
Ideal Help Would be to have someone with a Slant Lathe Pull Their Settings From The Emerson VFD for the I.O. (Thank You rdsi)
Manuals: SK Reference | SK Advanced | WJ200
Emerson = Hitachi
T1 = L Lower
T5 & T6 = N/A (This is an E=Stop if Closed Prob Will set it to Normally Open Alarm Relay AL0-AL1 on the Hitachi.)
B1 = ? See Below (Will Assume Will Go to O on the Hitachi but could be EA also)
B2 = P24
B3 = ? See Below
B4 = N/A (Drive Enable Tied to B2 24V Pins 9 & 10 on BOB)
B5 = 1 (Forward)
B6 = 2 (Reverse)
B7 = ? See Below (Solved EA) Set WJ200 A001 Frequency Source to 06 Pulse.
From the Emerson Manual
B1 Analog Voltage Output - Motor speed
Voltage Output 0 to +10V
Scaling 0V represents 0Hz/rpm output +10V represents the value in Pr 02 Maximum set speed
Maximum output current 5mA
Resolution 0.1%
B1 Tormach Setting
A Voltage proportional to output current again not sure how to translate that to Hitachi WJ200 settings .
B3 Digital Output - Zero Speed (or Digital Input)
Voltage Range 0 to +24V
Maximum Output Current 50mA at +24V (current source)
B3 Function Tormach Settings
N=0 Zero Speed ??? How does that Translate to Hitachi WJ200 settings.
B7 Digital Input - Local/Remote Speed Reference
Logic Positive
Voltage range 0 to +24V
Nominal threshold voltage +10V
B7 Function Tormach Settings
Fr Frequency input Using Pulse Train Setting and EA On Hitachi WJ200
BOB to Emerson VFD
WJ200
CNC Machines: Tormach PCNC 1100 CNC Mill W4th Axis | Birmingham 12X36 Lathe W/ CNC Retrofit W/Tormach BOB PathPilot & SKCD200220 VFD | My Personal Blog www.stevenrhine.com
I have some spindle control now thanks rdsi.. just a small window about 5HZ will have to dive deeper in to the settings thanks a bunch. Got the ProDriveNext Software up and going now also.
Still have not connected B1 & B3 due to deciphering language... but Changing Hitachi P055 Pulse Train Freq. Scale from Default 25 to around 2.9 gets me very active spindle movement wi change of spindle speed.. But not what it should be at 1000RPm may be getting 800 or 1200
Hello Contract_Pilot
Can you identify the Large IC just to the left of PN 32574. Do you by chance have any high resolution images of this board?
Thanks,
Iron-Man
PIC16F1947
I noticed that J2 connects to the turret control board. The PIC has signals that terminate at J2.
The PIC has "Capture/Compare/PWM Peripherals 5 Input Capture, 2 CCP, 3 ECCP,"
I am almost certain that the PIC16F1947 is used to decode the PWM signals form PathPilot to control the turret.
Have you by chance tried to download the code on it?
Thanks,
Iron-Man
