Anyone used the rotary around the Z axis with fusion 360 and pathpilot? I'm trying to make a part that is a hair more than the Y axis travel but for the life of me can't get it to rotate the part. Not sure if it is a Fusion problem or a problem with the post as the simulator rotates the tool not the part on 4th axis moves. One problem I have is if I set the post option to around Z it outputs the rotary as C axis and path pilot doesn't know what to do with that. Best I have come up with so far is to make 2 different setups and then manually add the A axis 180 deg move. I started looking at other posts for different machines but they only A axis options on the ones I opened and gave me same results. When changing the tool orientation doing the same cut it starts 180 from the first one that is kinda pointing me to a post issue I think???
