Also, it comes with status messages like "program exceeds machine minimum on x-axis by: 74 inches"
Hello
I own a 440 and have run into this problem before, but the usual solution isn't working now. When referencing the x-axis, the limit switch engages but doesn't stop the table like usual. The motor continues to run and the DRO shows the x-axis position just going and going with no end. The solution in the past has been to move one of the limits to a place where the table wants it to be, not working now. Any suggestions?
thanks
Turns out the X limit switch isn't firing - so the new question is, any suggestions on how to troubleshoot a faulty limit switch?
Get a new one from them
When you trip the switch manually did the light on the status page illuminate?
Yep. If it's the microswitch innards, that's a replace, not a repair.
Or build an optical switch
http://www.cnczone.com/forums/tormac...pathpilot.html
Thank you for the responses. It was a gunked up limit switch, now I just manually check to see if it's firing before referencing the x-axis. Sometimes it takes pressing it a few times but is working for now.
If you exceed the limit switch position you should be hitting a hard stop at the end of travel. If your motor continues to run, you are most likely slipping somewhere, I would check the motor coupling. It sounds like you have a problem switch and it should be replaced ASAP, It isn't good for the machine to be running into a hard stop. It stresses the entire drive train.
Regarding optical limit switching, I installed optical homing on my 770. I retained the OEM limit switches but with the optical homing and PP's soft limits, I never hit the OEM switches any more. Details are in another thread on this forum.
R J
I have a different view of running a stepper motor into a hard stop. If the mechanics are robust enough, and the Tormach is, a hard stop will do no damage even after multiple stops. On some (all?) machines Tormach uses a resilient doughnut on the screw to moderate an axis deceleration when a limit switch fails.
