Shop Vac - Is It okay to run for extended period
Results 1 to 3 of 3
Thread: Shop Vac - Is It okay to run for extended period
    Oct 2010
    Default Shop Vac - Is It okay to run for extended period
    Got a plastic mold making question - as it relates to a shop vacuum. I have a ShopVac contractor series 14 gal / 6.5 amp. I've got a dust shoe hooked up to the spindle and the dust shoe hooked to my shop vac. Now, on these 3D parts the vac might have to run for 3 or 4 hours..... Anyone ever ran theirs for this length of time before? I'm trying to avoid getting a Rockler Tool dust collector because of room in the shop.
    Thoughts?
    Thanks,
    Awall
    Awall - The Body Armor Dude
    CoolCNCStuff_ on Instagram - CoolCNCStuff.com
    Dec 2003
    Default Re: Shop Vac - Is It okay to run for extended period
    Shop Vac's and central Vac's being Universal motors that run at high rpm, as most serial motors essentially in a run-away condition, so the bearing and the brushes take the brunt of it, Just make sure they do not run with any blockage as although the current goes down, the heat and rpm goes rises.
    Dec 2013
    I ran my ShopVac, same one you have, for 4 days straight one time. It lasted another 3 years in normal use before the power switch finally failed and I retired it.
    Jim Dawson
    Sandy, Oregon, USA
