Chatter, once it starts its hard to get rid of, I would try reducing RPM. With that much stickout its going to be a problem, chatter is a resonance of the tool or work piece or both, There may be cutters specifically ground to reduce it I am not sure, I know it works on lathe boring bars by reducing the back relief of the cutting tool and varying the doc and rpm.
I try to use the shortest "fattest" tools I can.
long tools and high RPM = Chatter, just my rule of thumb.......
I really havent found a good cure for it, what works in one situation may not work in another.
