I don't understand how motorcycles have anything to do with tightening a 5 inch Tormach vise.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
We'll considering that no one had a good answer as to the torque question I figured Kenny and I could share motorcycling stories
Did hear back from Tormach and they do not have a "recommended" setting. Guess that's how they would be able to deny a warranty claim....
Awall - The Body Armor Dude
CoolCNCStuff_ on Instagram - CoolCNCStuff.com
That's exactly why I use a inch pounds torque wrench.
But the way this post started out, it sounded like the man was trying to hold 3 parts at one time.
I have never had success holding 3 parts, but I have held 2. One on each end of the vise jaw.
Hey Steve,
Well yes... I was talking about doing the three part in one vise and appreciate the feedback you provided. But my main question had to do with recommended (max) torque on the screw. So, since you are using an inch pound torque wrench, what In Lb settings are you using?
Thanks,
Awall
I think consistency is more important than an actual "max" number.
Obviously you don't want to crack the vise, and you don't want your parts to come out. If you're accomplishing this, and applying the same torque each time then I wouldn't be too concerned with trying to find that max torque value.
Yep, at the end of the day all I was trying to do with this post was find the, "hey - if you tighten your vise above this # you are going to jack up your stuff". With that knowledge, if a part cannot be tightened via the vise pressure then you at least rule out that variable.
If you are going to try 3 then you need something like some silver solder to take up the minor differences. Works for small stuff on occasion.
I have been enjoying making fixtures for multiple part jobs. Miteebite clamps are awesome.
This one takes 2 10" long bars and turns them into 6 pieces. The clamps hold very well even after the split. You could look at carvesmart jaws and miteebite clamps then no workholding issues after that (if your budget allows)
https://i.imgur.com/XEkNjNf.jpg
https://i.imgur.com/35yPP0n.jpg
thought I had a pic of it finished.. guess a cad screen shot will have to do
https://i.imgur.com/RrQxRmt.png
Couple months ago I was looking at that plate and asked if he road a wide bike
This is a great answer. To this day a 10 mm wrench feels perfect in my hand and I can torque a bolt to spec by feel alone.
A good read!
While back I did a double take thinking, Kenny Roberts. Talk about old school
