Any good HSM CAM should allow you to specify a different feed rate to use within a specified distance from an inside corner. That will largely eliminate chatter in the corners. I don't know if SprutCAM supports it or not, but HSMWorks/HSMXpress/FusionCAM does.
Regards,
Ray L.
