Pneumatic pressure switches are readily available, and cheap, in almost any pressure and switch configuration (NO, NC, etc.) you can imagine. Simply Tee it into the air supply, and wire it to disable the PDB air solenoid if the pressure is low.
Regards,
Ray L.
