Back off on depth, and I suspect you'll be able to actually increase feed. At 0.025" WOC, I can easily do 1/2" DOC at 150 IPM. At 0.05" WOC, I do 1/2" DOC at 110 IPM. That's using a cheap ($12) HSS 2-flute, and neither is stressing the machine or the tool in the slightest. Use a helical entry with 5 degree ramp to do most of the initial removal in the pocket, using as large a radius as will fit, while completely clearing the center of the pocket. Unfortunately, your MRR is going to be limited by your machines limited RPM and feedrate, not by the tool.
Something else to try - with HSM, you can often get away with using a 4-flute tool, even for pocketing, which allows you to increase feedrate even further. So, you might get a better result using a 4-flute tool, and greater depth.
FWIW - I've always found HSMAdvisor to be much better at coming up with optimal feeds and speeds than GWizard.
Regards,
Ray L.
