I purchased mine about 4 months ago. No pin in it.
Please tell me if your Rapid Turn spindle has a pin that keeps the 5c collet from turning when you tighten it up. Per Tormach, there is a hole for a pin but they do not come with a pin in the hole. Is that true? THANKS
Awall - The Body Armor Dude
CoolCNCStuff_ on Instagram - CoolCNCStuff.com
If you need to use a square or hex 5c collet and align the material (sides) with the Rapid Turn's indexing notches for milling (i.e. with the RT disabled but using it as a 5c indexer), the pin wouldn't help. I'm pretty sure any 5c fitments including the 3-jaw chuck are held adequately with normal clamping force.
Andy
Thanks Andy. I was thinking the purpose of the pin was to keep the collet from turning in the spindle as you tighten the draw bar not for index positioning.
Yes, it is, but the RT has the useful indexing feature, so if you're using square or hex collets and want to align the material 'radially' with (e.g.) the square flats horizontal/vertical at 0 degrees on the index wheel, you'd be unlikely to do this with the pin in place. With a mill or lathe spindle (without an indexing facility), the pin's there for anti-rotation.
Andy
Got it, but there is no pin in my Rapid Turn spindle. That was my question. Is it a mistake that I don't have a pin in the hole or are all of them that way?
Dah.......Okay, that makes sense. None of my other machines have an indexing capability. Thanks
