Video 4th AXIS SET UP AND RUN PARTS - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 26 of 26
Thread: 4th AXIS SET UP AND RUN PARTS
  1. #25
    Dec 2008
    Switzerland
    Default Re: 4th AXIS SET UP AND RUN PARTS
    Well that didn't take long...
    For those of you with the All Post version, in the post processor generator open the Machine Information dialog and deselect NC block numbers:
    4th AXIS SET UP AND RUN PARTS-disablelinenumbers-png
    Step
  2. #26
    Jun 2012
    Quote Originally Posted by TurboStep View Post
    Step
    Excellent!! Thanks
    BTW. Mach3 seems to completely ignore line numbers as well. You can add lines of code with no numbers while all the other lines have numbers, copy complete sections of code with numbers and paste elsewhere so the numbers are out of order. Has no affect.
    Good to know PP works the same, for when I finally decide it is time to switch (and re-write all my macros).
